Thread: Extract Line & Arc information, then place in a note with a leader
    All AUGI, all the time cadkiller's Avatar
    2003-09
    Bergenfield, NJ
    697
    Default Extract Line & Arc information, then place in a note with a leader
    Group;
    Say you have a line or an arc and you want to set something up that will give you all the information of that object in a note with a leader automatically.
    For example you have a line on an angle and want the length of that line, pitch on 12 and degree to be listed in the note. Also for arcs it would give the length of the arc, middle ordinate, radius and degree.
    What is the best way to set this up? Any ideas would be appreciated.
    2006-02
    Croswell, Michigan
    80
    Cool Re: Extract Line & Arc information, then place in a note with a leader
    Try the list command, highlight desired information, copy to clipboard and then paste into mtext. You will have to modify items inside the mtext editor to look correct. Finally a qleader should finish the task for you. Is there a better way, maybe. This beats writing information on a scrap of paper.
    2004-08
    Iron Station, NC
    3,198
    Default Re: Extract Line & Arc information, then place in a note with a leader
    Quote Originally Posted by cadkiller
    Group;
    I would request that someone move your post to the AutoLISP Forum so someone can write a quick little program for you.
  1. Leader Note font
    By alan.123099 in forum AutoCAD General
    Last Post: 2009-03-23, 08:00 PM
  2. Easily extract information from a PDF into a database
    By thomas.stright in forum Software
    Last Post: 2006-12-20, 09:47 PM
  3. Extract entity information from within an xref
    By marc.primaroh in forum AutoLISP
    Last Post: 2006-04-10, 11:34 AM
  4. Script to extract attribute information
    By sifuentes in forum AutoCAD Customization
    Last Post: 2005-07-07, 01:13 PM
