Results 1 to 6 of 6
Thread: DOOR STYLES
    2003-11
    231
    Unhappy DOOR STYLES
    Ok im having a problem with my door styles they are showing a fill when i place them in the drawing and this is true with all styles. I am unable to find where to turn this fill off. I have looked everywhere in the display manager. can anyone help me out?
    -RUSS-
    ACA/AMEP Forum Moderator arcadia_x27's Avatar
    2003-10
    The 'Mill,Moncton, NB, Canada
    516
    Default Re: DOOR STYLES
    What version of ADT are you using? And can you post a sample drawing so that others might be able to help you troubleshoot it? offhand I'd say maybe your detail level is set to High, try setting it to medium and see if that corrects the problem.
    2003-11
    231
    Ok here is a piece of the drawing that i am working on. and i did try the detail levels before and i did not get the result i was looking for.
    -Russ-
    2003-11
    231
    Im sorry i am using 2004 ADT
    2003-10
    516
    Does this fix your problem? You had the drawing shaded,when you switch to wireframe your solid doors disappear. The walls were supposed to be filled in right? They didnt change.
    2003-11
    231
    Smile Re: DOOR STYLES
    that did it thank you i knew there was something simple that i was missing.
    thanks
    Russ
  1. Door Styles
    By Andy.88917 in forum Style Management
    Last Post: 2009-03-30, 03:23 AM
  2. Specialty Door Styles?
    By jaroguy in forum ACA General
    Last Post: 2006-07-26, 11:59 AM
  3. Door styles to modify
    By Matt Mercer in forum ACA General
    Last Post: 2005-04-29, 02:59 AM
  4. Door Styles
    By BCrouse in forum ACA Wish List
    Last Post: 2005-04-07, 03:24 PM
  5. Door styles
    By dpasa in forum Revit Architecture - Families
    Last Post: 2004-09-02, 01:04 PM
