Thread: Surface boundary causes surface errors
    2005-08
    40
    Default Surface boundary causes surface errors
    Hi,
    Can someone give me some work around on the following problem:
    I created a surface from a corridor and I created a boundary which needs to run inside the surface in certain areas to outline a proposed headwall.
    I noticed that as long as the boundary follows the boundary created by Civil3D the surface acts nicely but if the boundary runs inside the surface, Civil 3d starts to cut out swatches within the surface. see attached JPG files
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    6,836
    Default Re: Surface boundary causes surface errors
    Quote Originally Posted by cblendermann.91943
    Hi,
    Just a guess since I do not use Civil 3D. The boundary you are using is removing points from your surface. Can you interpolate points around your boundary? This should provide your surface with points to finish the contours you are looking for.
    I hope that makes sense. I don't know the Civil 3D terminology to better explain it.
    Civil Engineering Moderator civil3Dguide's Avatar
    2006-01
    Temecula, CA
    281
    When creating the boundary are you using destructive breaklines? It would appear that the breaklines being created by the new boundary are non-destructive, the naming scheme of the breaklines tend to be confusing, making most people think the opposite reaction will take place when making this choice.
    2005-08
    40
    Smile Re: Surface boundary causes surface errors
    Quote Originally Posted by Christian Barrett
    Christian,
    Thank you for the tip. I removed the boundary from my surface and reatached it and checked the box for "non-destructive breakline" which then resulted in a properly bound /cut back surface.
    Have a great day
    Cord B
  1. Add Boundary to TIN Surface
    By BlackBox in forum AutoLISP
    Last Post: 2010-10-11, 09:14 PM
  2. crop surface and a boundary
    By eleonard in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2010-06-29, 11:52 AM
  3. Surface Boundary Issues
    By clarkl in forum AutoCAD Civil 3D - General
    Last Post: 2007-12-11, 03:36 PM
  4. Boundary intersects itself. Surface boundary could not be applied.
    By brian.59027 in forum Land Desktop - General
    Last Post: 2005-10-13, 02:35 PM
