Thread: Inserting a Block and entering Attribute values on command line
    2015-12
    385
    Question Inserting a Block and entering Attribute values on command line
    Hello all,
    I am trying to insert a block (which has several attributes) and I would like to enter the attribute values on the command line and not recieve the pop up window (Edit Attributes Manager). Is this possible? attached is the block and a my lisp
    ;Calc Block
    (defun c:cab (/ currlay)
      (command "undo" "begin")
      (setq currlay (getvar "clayer"))
      (command "-layer" "make" "m-quco-chck" "")
      (command "-insert" "T:/AEI CAD/Lisp/LISP SUPPORT/ROOM CALCS BLOCK.dwg" "s" 1 pause 0)
      (setvar "clayer" currlay)
      (command "undo" "end")
      (princ))
    AUGI Addict .T.'s Avatar
    Lost
    1,473
    Default Re: Inserting a Block and entering Attribute values on command line
    Quote Originally Posted by ReachAndre
    Hello all,
    ;Calc Block
      (princ))
    Hi Andre,
    Have a look at the ATTREQ and ATTDIA system variables and getvar/setvar them appropriately.
  1. How to change dynamic block attribute default values based on block selected?
    By zeirz109180 in forum Dynamic Blocks - Technical
    Last Post: 2013-12-13, 02:20 PM
  2. Block Attribute Table Values Dont' Appear in Block
    By stusic in forum Dynamic Blocks - Technical
    Last Post: 2011-12-27, 02:58 PM
  3. 2010: Block/Attribute/Command Line
    By jarrod822295 in forum AutoCAD 3D (2007 and above)
    Last Post: 2011-11-10, 10:03 AM
  4. Replies: 4
    Last Post: 2008-11-13, 05:36 AM
  5. Replies: 4
    Last Post: 2006-03-02, 04:13 PM
