Results 1 to 7 of 7
Thread: Using MText command inside a routine, display Editor instead of command line version
    2005-10
    8
    Default Using MText command inside a routine, display Editor instead of command line version
    I'm creating a program to setup standard text style and layer from dialog box menu. At the end of the lisp program I'm using "Mtext" command to created the text entity.
    ((vl-cmdf "-mtext")
          (while (not (zerop (getvar "cmdactive")))
    	(command pause)
    When I call the Mtext command inside AutoLisp the Text option tool bar does not show up in the graphic screen. I can only enter the text string from the command prompt. Any suggestion on working around this issue will be appreciated. You can reach me at paulmon@sympatico.ca
    Best Regards,
    Paul Mon
    AUGI Addict .T.'s Avatar
    Lost
    1,473
    Default Re: Using MText command inside a routine, display Editor instead of command line version
    Quote Originally Posted by paulmon
    ((vl-cmdf "-mtext")
    (command pause)
    Best Regards,
    Paul Mon
    Hi Paul,
    I haven't used vl-cmdf, so I don't know how to get there using it, but maybe this using the command function will help:
    (defun c:test ( / ocmd)
      (setq ocmd (getvar "cmdecho"))
      (setvar "cmdecho" 1)  ;so the standard prompts show up
      (initdia)   ;Tells the interpeter you want to use the dialog box in the next command
      (command "mtext") ;notice no dash
         (command pause)
      (setvar "cmdecho" ocmd)  ;set cmdecho back as it was before
      (princ)
    HTH
    2005-10
    8
    Thanks Tim!
    It works just the way I wanted.
    Best Regards,
    Paul Mon
    Lost
    1,473
    Thanks Tim!
    Best Regards,
    Paul Mon
    You're welcome; I'm glad it worked for you.
    Lost
    1,473
    Thanks Tim!
    Best Regards,
    Paul Mon
    I started thinking about it, and I don't think you need the cmdactive while loop for this to work:
    (defun c:test ()
      (initdia)
      (command "mtext")
      (princ)
    Should work.
    Give it a try and see.
    2005-10
    8
    Question Re: Using MText command inside a routine, display Editor instead of command line version
    Hi Tim,
    I really appreciated your helpful suggestion. It work fine initially. Just recently I've added a few module to my program and complied the program into vlx. No when I run the program I get:
    "no function definition: INITDIA"
    I compile the code with the code with Standard mode
    One module for each file.
    I compiled the following into vlx as a single module and it run fine.
    (defun c:LMTEXT ( / ocmd)
         (command pause)
      (princ)
    I've spend half a day checking through my other code and still don't have any idea on what cause this problem. Any suggestion will be appreciated.
    Lost
    1,473
    Hi Tim,
         (command pause)
      (princ)
    That's something I haven't run into, but try adding (vl-arx-import ’INITGET) as the first line of the file you are trying to compile. I can't test it at the moment, so let me know. Or I'll test it tomorrow.
    HTH
  1. Command Line Version for All Dialog Boxes
    Last Post: 2013-11-27, 04:32 AM
  2. Check Standards via the command line or a routine
    By cadmancando in forum AutoLISP
    Last Post: 2006-05-24, 11:06 PM
  3. Replies: 4
    Last Post: 2006-05-09, 08:57 PM
  4. Replies: 4
    Last Post: 2006-02-03, 07:34 PM
  5. Qleader prompts for MText via command line
    By okonforti.91529 in forum AutoCAD General
    Last Post: 2005-09-28, 09:38 PM
