Results 1 to 10 of 12
Thread: Show X,Y coordinates by using dimension or by other means?
    2002-11
    Default Show X,Y coordinates by using dimension or by other means?
    Dear members,
    How can I show X,Y coordinates by using dimension command or any other commands,
    eg. I have a point marked using North and East coordinates in a Map. I want to show that coordinates by text.
    Please help, Thanks
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,105
    Default Re: Show X,Y coordinates by using dimension or by other means?
    Try the attached block. It contains a FIELD for each Attribute. Edit it to what you need. If you move the Block around in your drawing, the FIELDs will update based on your FIELDEVAL system variable.
    2016-02
    Sydney, Australia
    512
    Use the Ordinate dimension to give either the X or Y position, or use Opie's/your own dynamic block to display both. I prefer the Dynamic block method, as you can export it all to a schedule quite easily.
    2016-02
    Sydney, Australia
    512
    Cool Re: Show X,Y coordinates by using dimension or by other means?
    My example of coodinate dynamic block with a table (in Acad 200.
    Tell me what you think?
    2003-12
    Pittsburgh, PA
    355
    This one will allow you to pick a new origin if you should so choose
    ;;;Annotate a Northing/Easting w/ a boxed leader, LPS 2008
    (defun C:CoordLeader (/ oldecho pt1 pt2 txtn txte dg)
    (setq temperr *error*)			;store *error*
    	(setq *error* errortrap)		;re-assign *error*
    	(setq oldecho (getvar "cmdecho"))	;restore variables
    	(setq oldlayer (getvar "clayer"))
    	(setq oldsnap (getvar "osmode"))
    	(setq olddimgap (getvar "dimgap"))
    (setvar "cmdecho" 0)
    (setvar "dimgap" -0.1)
    (command "undo" "m")
    (setq ptb (getpoint "Pick base point:  <World>"))
    (if  (not (null ptb))
    (command "ucs" "o" ptb)
    (command "ucs" "o" '(0 0))
    );if
    (setq pt1 T)
    (while  (not (null pt1))
    (setq pt1 (getpoint "\nPick coordinate point: "))
    (if pt1
    (progn
    (setq pt2 (getpoint  pt1 "\nPick text location: "))
    (if pt2
    (progn
    (setq txtn (strcat "N: " (rtos (cadr pt1)2 2) " "))
    (setq txte (strcat "E: " (rtos (car pt1) 2 2) "\n"))
    (command "leader" pt1 pt2 "Annotation" txtn txte "")
    );while
    (setvar "cmdecho" oldecho)
    (setvar "dimgap" olddimgap)
    (command "ucs" "p")
    (setq *error* temperr)
    (princ)
    );defun
    (defun errortrap (msg)				             ;define function
    	(command "undo" "b")
    	(setvar "osmode" oldsnap)			;restore variables
    	(setvar "clayer" oldlayer)
    	(command "ucs" "p")
    	(setq *error* temperr)			;restore *error*
    	(prompt "\nResetting System Variables ")	;inform user
      (princ)
    );defun
    2008-02
    11
    Wink Re: Show X,Y coordinates by using dimension or by other means?
    Use pulldown menu : LABEL / NORTH - EAST
    pick the exact point to measure
    N/E coordinate data is calculated
    pick a spot on-screen to place the N/E text
    then you can draw a pline or leader to the text if you want
    Make sure you are in UCS WORLD
    Still, there could be a better way
    I PLEAD DUMBNITUDE !
    2002-01
    jUSt Here (a lot)
    9,105
    Quote Originally Posted by simons_d View Post
    Simons_d,
    Which vertical are you using? I don't believe that is an option in vanilla AutoCAD.
    2012-03
    Quote Originally Posted by Norton_cad View Post
    Thanks your sample drawing is very useful
    2016-02
    Sydney, Australia
    512
    No worries mate.
    2013-10
    Smile Re: Show X,Y coordinates by using dimension or by other means?
    Quote Originally Posted by lpseifert View Post
    );if
    (setq pt1 T)
    (if pt1
    (progn
    (if pt2
    (progn
    );while
    (command "ucs" "p")
    (princ)
    );defun
        (command "ucs" "p")
      (princ)
    );defun
    thanks a lot
  1. Show Clash Symbol When a Dimension Overlaps Another Dimension
    Last Post: 2013-11-18, 08:31 PM
  2. Replies: 0
    Last Post: 2013-08-10, 10:46 AM
  3. DIMENSION TICKS DO NOT SHOW
    By AutoCAD Vancouver in forum AutoCAD General
    Last Post: 2009-08-26, 09:44 PM
  4. Replies: 9
    Last Post: 2006-07-29, 07:48 AM
