Thread: HSS family errors
    54
    Default HSS family errors
    There seem to be errors in the HSS-Hollow Structural Section-Column.rfa file (RS4 imperial library).
    Some of the 3-1/2x3-1/2 tubes have dimensions of 3.5"x2.5" (they are rectangles, not square). And some of the 3-1/2x2-1/2 have dimensions of 3.5"x3.5" (square when they should be rectangles).
    Has this been discussed before and I missed it? Is anyone aware of a fix from Autodesk?
    ~Sarah
    2002-09
    Madison, WI
    4,439
    Default Re: HSS family errors
    Hi sarah, there's also issues when using HSS tube and then trimming them. The hidden lines don't go away when coping.
    Dave Peterson
    Acad 2012 - Revit Structure 2013 - Z220 - Win 7 64 - i7-3770 3.4GHz 32GB Ram
    "The more you know, the less you know, because the more you know you don't know". --M. Lin
    2001-07
    29
    The Angle family also has errors. I've gone in fixed the type catalog file.
    I think its the sizes with 1/2's they don't put the 0.5's in the file.
  1. No Errors?????
    By thomasel98 in forum Revit MEP - General
    Last Post: 2010-10-01, 05:34 PM
  2. How do I fix these errors
    By Chowdur in forum Revit Structure - General
    Last Post: 2010-03-02, 11:14 PM
  3. Revit 2009 - Serious Errors Occurring Related to Family Parameters
    By christian.69744 in forum Revit Architecture - General
    Last Post: 2009-05-28, 04:32 PM
  4. Fatal Errors, run time errors
    By carmen.martinez in forum AutoCAD General
    Last Post: 2008-04-17, 02:12 PM
  5. ARX errors - why are they there?
    By dalewww in forum AutoCAD General
    Last Post: 2007-08-03, 02:03 PM
