Thread: Point location
    2002-11
    13
    Default Point location
    Working in Autodesk Land Desktop 2006. I brought in a point file using the import points command with the format of PNEZD. I noticed that they all came in about 15' (in the same direction) from where they should have. If I pick on the point and list it, it shows the correct northing and easting, but the marker location is at the wrong coordinate. So when ever I try to do anything with points it is using the marker location which is wrong. Also, I just imported them into a new project and everything came in where it should.
    Thanks for any help,
    Wayne
    2002-11
    13
    Default Re: Point location
    I found the answer. I had previously checked to make sure my "base" was set to 0,0,0; but that is an AutoCAD command. I did not check under Projects/Drawing Setup/Base Point. Someone had changed this from 0,0,0 for some reason. Dirty little gremlins.
  1. Autolisp function to determine point location
    By BrenBren in forum API Wish List
    Last Post: 2010-09-28, 03:45 PM
  2. Location Point
    By djn in forum Revit - API
    Last Post: 2009-05-19, 09:05 PM
  3. Selecting location point with mouse
    By topi.hyrkas in forum Revit - API
    Last Post: 2008-07-09, 01:38 AM
  4. Insertion Point Location?
    By whdjr in forum AutoLISP
    Last Post: 2006-09-13, 06:49 PM
  5. Replies: 1
    Last Post: 2006-08-10, 07:06 PM
