Thread: Import a layout from a template using lisp?
    AUGI Addict .T.'s Avatar
    Lost
    1,473
    Question Import a layout from a template using lisp?
    Is it posible to import a layout to a drawing from a template drawing using lisp?
    If so, how the heck do you do it? Using (vlax-invoke-method 'copyfrom...)?
    TIA
    Lost
    1,473
    Default Re: Import a layout from a template using lisp?
    ~gildaradnervoiceon~Never mind.~voiceoff~ I didn't realize that layout in a command function doesn't pop the dialog to select the layout.
  1. New Layout From Template
    By stusic in forum AutoLISP
    Last Post: 2012-01-24, 02:01 PM
  2. Layout not available for import?
    By randyspear in forum AutoCAD Sheet Set Manager
    Last Post: 2008-01-30, 07:14 PM
  3. Insert Layout from a Template
    By bweir in forum VBA/COM Interop
    Last Post: 2007-03-21, 06:43 PM
  4. Replies: 0
    Last Post: 2007-02-02, 03:44 PM
  5. Import layout from another drawing
    By claus in forum AutoCAD Tips & Tricks
    Last Post: 2006-03-22, 03:14 PM
