Thread: How to gt symbolic lines to show when object out of view range
    I could stop if I wanted to Maximillian's Avatar
    2006-09
    258
    Default How to gt symbolic lines to show when object out of view range
    I have a range hood that is set to be 6' above the floor (out of view range). in the hood family I made the hood model not visible in Plan view. But I added symbolic lines to show the outline in plan. I cant seem to get the lines to show up in plan. Is there a way around this?
    All AUGI, all the time eddy.lermytte's Avatar
    Belgium
    554
    Default Re: How to gt symbolic lines to show when object out of view range
    Try to add an Symbolic Invisible Line from hood to floor in your Hood Rfa.
    2006-09
    258
    Not sure what you mean...If I were in the " left" view of the family I would draw a line from the floor to the hood? Not sure what that would help?
    All AUGI, all the time ford347's Avatar
    2005-01
    Oroville, CA
    867
    That would help because now the family is being cut in your plan view, so the symbolic lines you had placed to show in plan view would now show up. As of now, your family is not being cut because it is placed above your cut plane, so this should help.
    Josh
  1. INTERIOR ELEV- SYMBOLIC LINES SHOW BEHIND CUT PLANE
    By JONB.102117 in forum Revit Architecture - General
    Last Post: 2011-08-03, 08:50 AM
  2. show hidden lines & view range
    By sfaust in forum Revit Architecture - Tips & Tricks
    Last Post: 2007-02-01, 04:58 PM
  3. VIEW RANGE - MY DOORS DON'T SHOW
    By khanson-3b in forum Revit Structure - General
    Last Post: 2006-12-22, 04:43 PM
  4. Symbolic lines in plan view.
    By Paul P. in forum Revit Architecture - Families
    Last Post: 2005-07-27, 06:39 AM
  5. How do you get symbolic lines to display on the exterior view of the door?
    By hdjohnson in forum Revit Architecture - Families
    Last Post: 2004-11-02, 09:08 PM
