Thread: SHARED PARAMETERS
    2006-07
    118
    Default SHARED PARAMETERS
    i am in the process of creating office standards for revit and am not sure what "shared parameters" is all about. any insights?
    AUGI Addict jeffh's Avatar
    2002-09
    Manchester, NH
    1,087
    Default Re: SHARED PARAMETERS
    A shared parameter is used if you want to have a parameter on a model object and also be able to report that parameter in a tag. The parameter is "shared" between the object and the tag. You can also use shared parameter to add parameters to objects beyond the standard parameters included on families out of the box.
    ______________________________________________
    Jeff Hanson
    Sr. Subject Matter Expert
    Autodesk, Revit User Experience
    All AUGI, all the time Justin Marchiel's Avatar
    2004-07
    Penticton, B.C., Canada
    954
    i would suggest that if you want that parameter to be scheduled or tagged at any point, you will want to make it a shared parameter.
    Justin
    2006-07
    118
    ok, i created a keynote shared parameter so i can place keynotes in my drawing. when i place a keynote under drafting, i don't understand the difference between element, material, or user. also, i might not have my keynote settings correct but the keynotes i place will not assign a number unless a keynote value is specified. ex). wall, ceiling, duct, etc.
    i want to be able to place keynotes into the drawing to call out random things, be able number them independently, and then have them automatically organized into a legend or schedule. is this impossible?
    2002-09
    Manchester, NH
    1,087
    From the way you are describing what you want to do a note block may be more appropriate. You may want to check the help files and tutorials for note blocks and keynotes to see which may be better suited to what you are trying to do.
    Jeff Hanson
  1. 2014: Criteria for Project Parameters vs. Shared Parameters
    By jagostinho134030 in forum Revit - Platform
    Last Post: 2014-03-21, 02:46 PM
  2. How YOU use shared parameters
    By enerGwizz in forum Revit MEP - General
    Last Post: 2011-06-24, 08:55 PM
  3. shared parameters
    By wags5116 in forum Revit MEP - General
    Last Post: 2011-05-19, 06:43 AM
  4. Shared Parameters
    By hpannu in forum Revit Structure - Families
    Last Post: 2007-10-23, 03:42 PM
  5. Shared parameters
    By Anthony.d in forum Revit Architecture - Wish List
    Last Post: 2006-12-31, 12:37 PM
