Thread: ADT2006 - ADT walls
    Active Member jaroguy's Avatar
    2005-11
    Minneapolis
    76
    Default ADT walls
    ADT 2006
    Please see the attached file. I have a 8" conc exterior wall with 3 5/8" met. stud and 5/8" gyp bd. The column enclosure is 2 1/2" met stud with 5/8" gyp.
    I am trying to remove 3 5/8" stud and gyp bd in the chase.
    I was told by some people saying add wall type (8"conc. wall) and replaced where we want to get rid of the stud and gypsum wall. Is there a different way to accomplish this without using two wall types? Is there any method to notch a portion of wall? Any help would be much appreciated.
    Jason
    2003-10
    San Francisco CA
    1,190
    Default Re: ADT2006 - ADT walls
    Quote Originally Posted by jaroguy
    ADT 2006
    Jason
    Hi Jason,
    Take a look at THIS thread and see if it helps. I suggested using a body modifier but I think others had better/different ideas.
    Scott Telthorst
    Quality Control Manager
    Helix Electric, Inc.
    www.helixelectric.com
    2002-09
    Madison, WI
    4,439
    Body/plan modifier is what you're looking for.
    Dave Peterson
    Acad 2012 - Revit Structure 2013 - Z220 - Win 7 64 - i7-3770 3.4GHz 32GB Ram
    "The more you know, the less you know, because the more you know you don't know". --M. Lin
    2004-05
    806
    I would use the plan or body modifier in this case, but I would not show the line representing the studs, as long as the scale is 1/4", or less.
  1. Titlemark-ADT2006
    By argh in forum Project Navigator
    Last Post: 2006-05-05, 03:03 PM
  2. ADT2006: Walls creation from ellipse shape possible?
    By joao_cota in forum ACA General
    Last Post: 2005-11-30, 03:14 AM
  3. ADT2006: Flat elevations of curved walls possible?
    Last Post: 2005-11-11, 10:16 AM
  4. ADT2006 custom walls
    By MetalliCAD in forum ACA General
    Last Post: 2005-11-04, 04:36 PM
