Everytime I import/link and copy/monitor the rooms and levels of an architectural model into my drawing it doesn't bring in the energy analysis information correctly. Not only that when I try to alter the energy analysis information and then export to gbxml none of my altered energy analysis information is exported just the room dimension. I've tried this on multiple linked background with the same problem. Im doing everything correctly in regards to linking and copying the rooms with the correct phasing and even tring to put room tags in my mep model for the imported rooms. Any help would be appreciated as the solution will dictate whether or not we will be using energy analysis on a project. Thanks.
