Thread: Viewing surfaces in AutoCAD
    2002-12
    Default Viewing surfaces in AutoCAD
    We have 1 license of Civil 3D and at times we need to view or print from AutoCAD. Can we view and print the plans with the surfaces in AutoCAD that were created in Civil 3D?
    AUGI Addict jpaulsen's Avatar
    2002-04
    Colorado
    1,901
    Default Re: Viewing surfaces in AutoCAD
    Yes. You may need to download and install the Civil 3D object enabler though. http://usa.autodesk.com/adsk/servlet...linkID=2475161
    If you have proxygraphics set to 1 in Civil 3D when you save the drawing the OE should not be required but the drawing size will be larger.
    Jeff Paulsen
  1. AutoCAD 2012 - Surfaces & Slice
    By MikeRobinson in forum AutoCAD General
    Last Post: 2011-04-26, 10:29 AM
  2. Text size problem when viewing C3D dwg in AutoCAD
    By Abflieger in forum AutoCAD Civil 3D - General
    Last Post: 2009-10-27, 10:18 PM
  3. Using Civil 3D surfaces in AutoCAD
    By digiwurx in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2008-01-17, 07:35 PM
  4. Replies: 3
    Last Post: 2006-07-19, 06:08 PM
  5. Viewing ADT objects in AutoCAD
    By jdodge2 in forum AutoCAD General
    Last Post: 2005-10-13, 02:42 PM
