Thread: Binding Xrefs
    2003-03
    Default Binding Xrefs
    I have 2004.
    I receive .dwg files of floorplans from Architects with xrefs.
    I hit the xref button and a list of xrefs comes up in the xref Manager dialog box, all showing loaded.
    I select the xrefs, hit bind, then select Insert and OK.
    The xref manager window is now blank indicating that there are no more xrefs.
    However the xrefs are not bound.
    When I pick the xref button again and the Manager dialog box comes up the same list of xrefs are there.
    I have been emailing out files to be bound. My techsupport guy has no such problem.
    I need help fixing this.
    Mike
    13,499
    Default Re: Binding Xrefs
    Hi
    Check out the following thread -
    NON BINDING X-REFS
    Have a good one, Mike
    13,499
    Hi Mike
    Please note I've *moved* this Topic (Thread) from the AutoCAD Customization Forum to this one as I believe it would be better served here.
    Thanks, Mike
    Forum Moderator
    I could stop if I wanted to LanceMcHatton's Avatar
    2002-04
    Las Vegas, NV, USA
    287
    You didn't mention what the command line showed when you tried to bind the xref. Usually, this is where AutoCAD will tell you why it can't do something. In this case, it may have said "Cannot bind because of multiple references" or "Cannot bind nested xref" or something like that.
    Whenever there's a problem, you should look at the command line. It is usually the best place to start when solving a problem.
    Good luck,
    Lance
  1. Dissapearing Xrefs when binding
    By john.panda in forum AutoCAD General
    Last Post: 2010-08-11, 03:00 PM
  2. Binding xrefs using ABS2006
    By kwortman in forum Software
    Last Post: 2008-07-11, 07:20 PM
  3. Etransmit not Binding Xrefs
    By cmolina in forum AutoCAD General
    Last Post: 2007-04-30, 08:38 PM
  4. Keeping layerstate when Binding Xrefs
    By thillhouse in forum AutoCAD General
    Last Post: 2006-03-30, 09:17 PM
  5. etransmit not binding xrefs
    By hostetterkl in forum AutoCAD General
    Last Post: 2005-06-02, 11:48 PM
