Thread: Network change, Tool Palettes address now defunct
    I could stop if I wanted to SRBalliet's Avatar
    2004-06
    In a loghouse, Looking for a job!
    495
    Default Network change, Tool Palettes address now defunct
    We had to make a network location change for our AutoCAD files. Does anyone know of an easy way to now repair the address that shows up under the properties menu of each Tool Palette item? We have hundreds. Its going to take forever by hand.
    Steve Balliet
    Craig Co., VA
    Civil 3D & Land Desktop 2008, Mechanical 2009
    AUGI Addict .T.'s Avatar
    Lost
    1,473
    Default Re: Network change, Tool Palettes address now defunct
    Quote Originally Posted by srb
    This may not help much if you are using several source files, but you can select multiple items in the palette by holding down the shift key, clicking in an open space, and dragging the selection box through those you want to edit. Once you have the group selected, right click one and select properties.
    I've never had to type with my nose before, but that was what was required to get the first screen shot I didn't have enough hands.
    HTH
    Tim Creary
    S&D
    DILLIGAF
    2004-06
    495
    Thanks Tim! I did not know you could pick more than one at a time on the Tool Palette! I thought I was going to have to do one at a time.
    Steve Balliet
    Craig Co., VA
    Lost
    1,473
    You're welcome.
    Tim Creary
    S&D
    DILLIGAF
  1. network shared tool palettes
    By revitrookie in forum ACA General
    Last Post: 2010-02-15, 01:35 PM
  2. Sharing Tool Palettes with other users on a network
    By austec in forum AutoCAD Customization
    Last Post: 2007-02-23, 06:59 AM
  3. Sharing Tool Palettes on the network from AutoCAD LT
    By Andrew Dobson in forum AutoCAD Customization
    Last Post: 2006-11-23, 05:25 AM
  4. Tool Palettes on the network
    By rgarthe in forum AutoCAD General
    Last Post: 2006-10-19, 06:25 AM
  5. Sharing Tool Palettes via the network
    By z66 in forum AutoCAD Customization
    Last Post: 2006-10-14, 02:52 AM
