Thread: How do I change/edit railing profiles?
    2005-11
    76
    Post How do I change/edit railing profiles?
    I found a previous thread on this issue and it didn't help me all the way.
    I used an existing profile family and re-saved it as my new profile, changing the sizes in the 'Family Types' box. I hope that's all it takes...
    I've highlighted the railing I want to change, hit Edit/New, hit Edit on the railing structure dialog box, hit the drop-down box to select the new profile I've loaded in but it's not there. The family category is also set to Railing, and I've tried changing it to <Generic> and that also doesn't work.
    The previous thread mentions a 'family browser' and I don't know where that is - any help on that please?
    I now believe that I've placed the new profile in the wrong folder because the profiles that I see in the drop-down box of the railing edit shows other profiles than the ones shown in the folder where I placed the new profile. Right now it's in Imperial Library/Profiles/Stairs. Is there another place where the profiles for railings are located?
    Axel
    Early Adopter sbrown's Avatar
    2003-05
    Coast to Coast
    4,440
    Default Re: How do I change/edit railing profiles?
    You need to load the new profile into your project. go to file -load from library, browse to where you saved the profile and select it. then it will be a choice for you to use. Or if you have the profile family open and your project open there is a choice on the tool bar to load into project.
    Scott D. Brown, AIA
    BECK
    He has it loaded. It just isn't showing up as a choice in the railing structure pull-down. I'm having a similar problem...
    I think he has it loaded, It just isn't showing up as a choice in the railing structure pull-down. I'm having a similar problem...
    Pittsburgh, PA USA
    1,906
    Quote Originally Posted by tyler.kawahara View Post
    Please be careful of the double post.
    That said, was the profile drawn on a Profile-Railing template? If not, you may not be able to use it in a railing.
  1. 2013: Angle of railing profiles not what I expected
    By mthurnauer in forum Revit Architecture - General
    Last Post: 2013-08-15, 12:32 AM
  2. Cannot Edit my Profiles?
    By daniel.260897 in forum AutoCAD Civil 3D - Profiles
    Last Post: 2010-09-10, 01:07 AM
  3. Can you edit stair nosing profiles
    By ian.112359 in forum Revit Architecture - General
    Last Post: 2009-11-29, 02:00 PM
  4. Railing Profiles
    By andrew.146851 in forum Revit Architecture - General
    Last Post: 2007-09-25, 05:47 PM
  5. Change Railing Base Level
    By Joef in forum Revit Architecture - General
    Last Post: 2006-12-19, 06:50 PM
