Results 1 to 10 of 13
Thread: DWF Print Problem
    All AUGI, all the time dsw98's Avatar
    2005-02
    Salt Lake City, Ut
    621
    Talking DWF Print Problem
    Why when I print from Revit my pages are what I want them to be. But when I Print the same file from a DWF the pages are getting clipped. Basicly the margins are changing between Revit and DWF. Is there a way to fix this without physically chaging the size of my Title Block?
    2005-05
    66
    Default Re: DWF Print Problem
    check on the scaling factor. keep it to 100% and the limits to center.
    and do it as print than export. it should work.
    I could stop if I wanted to The Sweg's Avatar
    2003-09
    Amish Country
    207
    What version of DWF Viewer are you using? I have experienced the same thing with several printers, and on several different computers and it only happened when I was using the latest version of the viewer.
    I kept an older version, and re-installed it and have no problems whatsoever. I haven't switched since because I'm afraid of getting the same results. Actually, I'm using DWF Composer to print from - the very first version.
    2005-02
    Salt Lake City, Ut
    621
    Talking Re: DWF Print Problem
    Quote Originally Posted by The Sweg
    Well here's the situation. I export to DWF then send that file to a builder. They try and print it and are the ones having the problems. So I thought I would try it. I am using the most current version of DWF viewer, which now seems like it could be a problem. I don't know how to get an older version of it. Where would I get DWF composer?
    2003-09
    Amish Country
    207
    I think you can download DWF Viewer directly from Autodesk website, it's around $100.00 (I think).
    However, if it's others having problems printing your DWF's, you might want to consider creating a PDF from your DWF, and then sending them that. We use DWF for everything in office, but whenever we send stuff out of office, we create a PDF since most everbody has Acrobat and not everyone is familiar with downloading viewers and such.
    Hope this helps,
    --Derek
    2005-07
    Somewhere in the BIM world
    3,792
    --Derek
    They're all pretty much free now
    --Derek
    To go around that we've posted the DWF viewer to our website and provide the client with a direct link to download the viewer so they get around registering ...
    2005-02
    Salt Lake City, Ut
    621
    Sorry I thought you said DWF composer, We already have DWF viewer. Maybe my client needs to download a newer version. Another off the wall thing. They said that when they print it it's printing a blank sheet in between sheets for some reason. I had no answer to that at all.
    2003-09
    Amish Country
    207
    My bad, sorry for the confusion. To clarify, the Viewer is free, Composer is not. Originally, I had issues printing from the newest version of the viewer, so I reverted back to an older version of the viewer that I had saved, however, I wanted some of the mark-up features and page-combining features that come with Composer, so we started using that. I am still using Composer, albeit one of the original versions.
    I hope you can find a solution, I know how frustrating printing problems can be - we've certainly had our share of them!
    2015-12
    Vancouver, BC Canada
    3,753
    To clarify, the Viewer is free, Composer is not. !
    Actually both are free (for the time being anyway)
    Composer is now called Design Review and can be had here
    http://usa.autodesk.com/adsk/servlet...112&id=5982524
    2003-09
    Amish Country
    207
    Quote Originally Posted by HCSL
    Thanks for that! I'm going to go download now to see if it's had some improvements from the antique version I have now. (I hope it stays free!)
  1. 2013: 3D View Print Problem
    By gdb in forum Revit Architecture - General
    Last Post: 2013-04-02, 06:25 PM
  2. Print Preview problem
    By davykerr1 in forum Revit Architecture - General
    Last Post: 2009-12-15, 09:56 PM
  3. Shadow Study print problem
    By Taylor A in forum Revit Architecture - General
    Last Post: 2008-11-28, 05:12 AM
  4. Oce Print/plotter Problem
    By jmedley in forum Hardware
    Last Post: 2008-01-10, 06:41 AM
  5. Perspective Print Problem
    By stuntmonkee in forum Revit Architecture - General
    Last Post: 2005-03-17, 05:34 PM
