Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Annotation - Graphic Scales
  1. #11
    Retired Forum Staff Chris.N's Avatar
    2001-12
    Rochester, MN
    2,561
    Default Re: Annotation - Graphic Scales
    Quote Originally Posted by noah
    This might be a stupid question but how do you use this bar scale? I inserted the block but it just shows as 3/32" = 1'-0". I can't figure out how to change it.
    Also, how do you get it to change automatically based on the viewport scale?
    Thanks!
    you can't get the 'bar' to update per the viewport scale, but you certainly can have the text update using fields in an attribute...
    lemme see if i posted my title marker way back when.....
    S&D DB Sharing Forum
  2. #12
    2001-12
    Rochester, MN
    2,561
    HERE is my version i posted way back when that is also set to be compatible w/ Sheet Set Manager projects.
  3. #13
    2005-06
    in the upper right corner
    3,508
    Thanks!
    To answer your first question, you click on the visibility states and select the one you want. Select the block and a "blue triangle" should appear to the top left of the block, that's the "visibility state button".
    You need to be running ACAD 2006 or higher to use DB's.
    See Chris's answer to your second question, he has too much time on his hands!
  4. #14
    2004-08
    183
    I'm not seeing the triangle when I "Insert" the block into my drawing. Is there a special way to "Insert" a dynamic block that is different from a normal block?
    If I open the block directly I see it but not when inserted.
  5. #15
    2005-06
    3,508
    It may be a nested block, try exploding it once and then see if you can see the "triangle".
  6. #16
    2015-12
    Near Charlotte, NC (Clover, SC)
    112
    Smile Re: Annotation - Graphic Scales
    Quote Originally Posted by tedg
    This was pretty neato!! At first I thought it was only in 2008 ACAD...but I flipped for joy when it was 2006. I'm going to use this every time I need a scale! Thanks.
  7. #17
    2002-09
    2
    I just have to say thanks to randall for providing the barscale drawing. It is really nice!
    Thanks again!
  8. #18
    2024-01
    How do I add a scale to this? I need to add 1/64" = 1'-0".
  9. #19
    Turlock, CA
    6,420
    First you add a visibility state. Then copy the bar from the 1/32 scale to the 1/64 scale and edit the feet values. I've done this for you.
    C:> ED WORKING....
    LinkedIn
  1. Replies: 10
    Last Post: 2022-08-25, 10:06 PM
  2. Annotation- Metric Graphic Scales
    By tedg in forum Dynamic Blocks - Sharing
    Last Post: 2009-05-25, 11:50 PM
  3. Purge Annotation Scales That Are Not the Current Active Annotation Scale
    Last Post: 2009-02-01, 06:04 PM
  4. Annotation Scales and Viewport Scales
    By Shizzjr in forum AutoCAD General
    Last Post: 2008-10-24, 05:42 PM
