Results 1 to 10 of 17
Thread: AutoCAD menu utilities loaded. ERROR: malformed list on input
    100 Club tomcarver's Avatar
    2015-11
    Tucker, GA
    106
    Default AutoCAD menu utilities loaded. ERROR: malformed list on input
    Hello All,
    I just noticed this error message after I start a new drawing and when I open an old drawing.
    Regenerating model.
    AutoCAD Express Tools Copyright © 2002-2004 Autodesk, Inc.
    AutoCAD menu utilities loaded.E R R O R: malformed list on input
    I noticed in my search for "malformed list" that this is a parentheses problem.
    Does this error mean that the problem is in express tools? I am assuming that when the error message refers to "menu utilities loaded" it means express tools. Do I need to look through all the .lsp in express tools?
    Any help will be appreciated.
    thanks,
    Tom Goodman
    Wilson, NC
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,100
    Default Re: AutoCAD menu utilities loaded. ERROR: malformed list on input
    It is probably not your Express Tools. Do you have any other routine loading during opening of AutoCAD or a drawing?
    in the upper right corner
    3,507
    Did you or someone else load a lisp routine in your "start-up suite" lately?
    If you or they did, the error is probably in that routine.
    To check. type "appload" and look into the "start-up suite" and see if there's anything there.
    That's where most people place lisp routines they want loaded in every drawing.
    There are other ways to automatically load routines though, but your IT guy would have probably done it.
    Just a thought.
    2015-11
    Tucker, GA
    106
    Hi Ted,
    Well, you caught me. I did look at a .lsp file that I thought was messing up and did some searching about malformed lists and tried to find the problem with VLIDE and probably misplaced a few parentheses. But the file still works. I got a copy of the file from a coworker and copied it over the suspect one. Could you look at the file or tell me how to find mismatched parentheses?
    thanks, Tom
    2015-11
    Tucker, GA
    106
    Hi Opie,
    We do have an old ACAD.lsp that we still use in the start up.
    2002-01
    jUSt Here (a lot)
    9,100
    Quote Originally Posted by tom.g
    Hi Ted,
    thanks, Tom
    Using the VLIDE you can use the Parenthesis Matching tool found under the Edit menu.
    You can also use the keyboard shortcuts to find them. The shortcuts are listed in the menu.
    3,507
    Quote Originally Posted by Opie
    Yea, what OPIE said. I don't use visual lisp much (VLIDE) but that would be a good thing to start with. I don't have any training in VLIDE, I've dabbled in it though.
    AutoCAD has an old routine called PQCHECK.lsp which checks lisp programs for mismatched parentheses and closing quotes. While in autocad, you load it, and to run it, the command is "pqcheck" and then you need to type the path of the routine you want to check ( ie: c:\lisp\sample.lsp) and it will tell you where your problem is.
    If you have an ACAD.lsp you may have some routines automaically loading through that.
    AUGI Addict kennet.sjoberg's Avatar
    2002-05
    1,707
    Quote Originally Posted by tedg
    . . .an old routine called PQCHECK.lsp . . .
    Copyright (C) 1992 by Autodesk, Inc.
    Time to take a step forward ?
    15 years later. . .VLIDE can do a LOT more than that.
    : ) Happy Computing !
    kennet
    2015-11
    Tucker, GA
    106
    Hi,
    Yeah, I remember, barely, using it years ago. It's a little touchy.
    Do you, or anyone, know if there is a white paper or an ATP class on VLIDE?
    THANKS
    2002-01
    jUSt Here (a lot)
    9,100
    Hi,
    THANKS
    I think one of the last Autolisp ATP courses had some information on it. I know it was not the last one though. You will probably have to wait another month or so till it is available.
  1. error: malformed string on input
    By Bear31831 in forum AutoCAD General
    Last Post: 2013-08-27, 06:50 PM
  2. Replies: 16
    Last Post: 2012-07-16, 07:41 PM
  3. Error AutoCAD menu utilities loaded.-layer
    By matthew.159401 in forum AutoLISP
    Last Post: 2011-02-03, 10:30 PM
  4. Replies: 7
    Last Post: 2010-02-05, 10:33 AM
  5. Replies: 4
    Last Post: 2006-09-28, 04:37 PM
