Thread: Convert AutoCAD DWG file to G-Code
    2007-02
    2
    Default Convert AutoCAD DWG file to G-Code
    I am helping my friend with a project he is doing on a small shop cnc machine. We have designed the wheel in AutoCad2006 and then insert the file into his CNC on board software which is BobCad. What happens is the BobCad software converts the file to G-Code and after doing so the drawing is all distorted.
    My question is what is the best way to convert the AutoCad file to G-Code ?
    We are both taking our first autocad class (in our 40's) in an evening adult continuing education course. That is how I was introduced to The AUGI group. The teacher has attended some of the AUGI functions and recommended to us that we visit the website.
    This was a beginning course that we are in and after taking this class we are now looking forward in continuing on with our AutoCAD development with the next level course.
    Jr.
    100 Club r424andy's Avatar
    2006-01
    In this Chair
    170
    Default Re: Convert AutoCAD DWG file to G-Code
    It all depneds on the software creating the g-code. From my past experience we had to save the cad file to a *.dxf file to import into the software.
    2007-02
    2
    Thanks for the quick response.
    The file extension that we saved it to was .dxf
    We tried several different times with the same file and during the conversion it nevers comes out 2 of the same.
    2005-08
    Albania
    423
    Quote Originally Posted by num1husker
    Jr.
    Have you tried to convert in 'step' -extension because is the best way for programming in CNC.
  1. Code to open an autocad file and run command
    By jitesh789 in forum VBA/COM Interop
    Last Post: 2009-02-23, 12:07 PM
  2. Replies: 1
    Last Post: 2008-10-14, 02:32 AM
  3. Replies: 0
    Last Post: 2008-10-13, 10:20 PM
  4. How to convert c++ output into AutoCAD dwg or dxf File
    By sunithbabu78 in forum AutoLISP
    Last Post: 2006-04-17, 01:36 PM
