Results 1 to 6 of 6
Thread: Revit Hatch Pattern Decoded
    I could stop if I wanted to Chirag Mistry's Avatar
    2004-06
    Atlanta
    254
    1 members found this post helpful.
    Default Revit Hatch Pattern Decoded
    This is something a collegue of mine put together.
    You can follow these rules to create certain custom patterns using notepad.
    AUGI Addict Scott Hopkins's Avatar
    2003-05
    Santa Barbara, CA
    1,197
    Default Re: Revit Hatch Pattern Decoded
    Very nice explanation.
    Thanks!
    2006-03
    London, UK
    810
    In http://new.cadalyst.com/code/members/oct05.zip, one of the lisp routines is Hatch Maker, where you draw in a 1x1 unit square in autocad and export as a pattern file.
    You can then use the hatch scale editor http://new.cadalyst.com/code/members/jan07.zip to change the scale of the apttern, or adjust the scale when importing to Revit.
    2002-02
    St. Louis, MO
    4,695
    Note that in the example - you end up with a hatch pattern that over a long distance will result in inaccuracies. 2.667 * 3 = 8.001 Seems small, but on big buildings I've had it result in rounding errors.
    A better pattern definition is:
    0, 0,0, 0, 8
    0, 0,2.667, 0,8
    0, 0,5.334, 0,8
    etc...
    This put the distance between any three lines at exactly 8" spacing.
    Both the AutoCAD and Revit patterns have the small inaccuracy....
    Don't drink the Kool-Aid...
    Aaron Rumple, AIA
    The Silent Type luigi's Avatar
    2015-11
    Royal oak, Michigan
    1,510
    It's good that you pointed that out....it's a huge deal even in a 2 story brick building...I've been meaning to do what you posted, but haven't had the time to modify the pat file....
    Thanks!
    Quote Originally Posted by aaronrumple
    0, 0,0, 0, 8
    0, 0,2.667, 0,8
    0, 0,5.334, 0,8
    etc...
    2005-07
    3,248
    How can I take a custom pat file I created and use it in Revit as a model pattern? It says that "No Model Type Patterns found". I know there's another method of importing a dwg with the hatch and exploding it, but I'd rather use the pat file directly. Anything that needs to be added to the pat file for this? Thanks.
    EDIT: Nevermind, got it. Just needed to add ";%TYPE=MODEL" to the pat file.
  1. 2016: Revit hatch pattern oddity.
    By david.metcalf in forum Revit - Platform
    Last Post: 2015-06-16, 04:57 PM
  2. Hatch/Pattern Editor in Revit
    By Andre Baros in forum Revit Architecture - Wish List
    Last Post: 2014-06-25, 07:46 AM
  3. Revit 2013 - Floor Surface Hatch Pattern
    By J17 in forum Revit Architecture - General
    Last Post: 2013-04-10, 04:41 PM
  4. Revit Earth Hatch Pattern
    By rroswall.242547 in forum Revit - Platform
    Last Post: 2010-02-17, 10:28 AM
  5. Replies: 5
    Last Post: 2008-03-16, 07:00 AM
