Results 1 to 9 of 9
Thread: 'PAST ITS END'
    2005-12
    134
    Default 'PAST ITS END'
    any idea what the error message....
    'an attempt was made to access 'ridgetop' past its end'
    means?
    ridgetop is the name of the project. a colleague got this error message when trying to open his project. is there any way to recover the file or do we have to go to the last backup? did we do something to cause the error?
    2005-07
    Somewhere in the BIM world
    3,140
    Default Re: 'PAST ITS END'
    When opening check the Audit option and see if it fixes it
    2005-12
    134
    Quote Originally Posted by dhurtubise
    still got the same error message.
    2005-07
    3,140
    Send it to support
    2006-07
    Melbourne, Australia
    38
    it means your file is stuffed.
    we had this happening at least once a day for the last month (large project, lots of people working in it - we think the problem was "saving to central"/network related but we couldn't pin it down to a particular computer/action that was causing it - it usally happened after we had 6 or 7 people accessing the central file, 3-4 hours after the start of the day or making new local files)
    recovering from the backups folder usually worked. if that didn't you got the most recent local file and made that the central. sometimes your local files worked. sometimes they didn't.
    100 Club jcdecastro's Avatar
    2006-03
    113
    Someone in my office the same message 2 minutes ago.
    Very small file 5.75 MB
    A title block was placed into the file. the file was saved and closed.
    An attempt was made to access the file then the error came up.
    The title block was an acad import
    2005-12
    134
    this is practically a brand new file (4.4 megs) as well. it is not a central file since we have only one person working on the project.
    2005-12
    134
    this message is happening with some regularity now and seems to be connected to the 'save as'. it is not a central file so that doesn't seem the cause in this situation. i still would like to know what the hell 'past its end' means.
    2006-10
    Arlington, Texas
    596
    Send it to support...
  1. What I used to do - silly past self...
    By jamesgchambers in forum Revit Architecture - General
    Last Post: 2010-05-19, 09:00 PM
  2. Why can't I see past the door opening?
    By narlee in forum Revit Architecture - General
    Last Post: 2009-08-25, 08:39 PM
  3. Past its end?
    By mthiessens in forum Revit Architecture - General
    Last Post: 2007-06-02, 03:04 AM
  4. Model past its end
    By rafterman in forum Revit Architecture - General
    Last Post: 2005-12-23, 09:37 PM
