Melarch
Tony,
Anyways, It is my understanding that Scope Boxes are designed to control datums, grid lines as well. Once you assign datum elements to a Scope Box then the Scope Box controls their visibility in any view. When you limit the height of the Scope Box, either when you sketch it's boundaries and set the height from the Level you are currently working from the Option bar or drag it up or down in a 3D view, the height will restrict those datum elements from being displayed above that Sope Box.
From the issue you describe it would suggest that in the Scope Box Element Properties dialog box in the Extents row - View Visible Edit button > Scope Box Views Visible dialog box that your 19th floor is set to Visible for the grids. That somehow those Grids became part of a Scope Box.
Mel Persin, AIA
