Results 1 to 10 of 16
Thread: Purge Blocks Only
    100 Club wpeacock's Avatar
    2003-10
    Bunbury, West Australia
    155
    Default Purge Blocks Only
    Is it possible to Purge Blocks only?
    I've used "ThisDrawing.PurgeAll" which, as it suggests purges everthing and gets rid of the blocks but this of course pruges stuff that I don't want to get rid of too.
    Thanks for your help.
    Wayne
    All AUGI, all the time zoomharis's Avatar
    2005-02
    Abu Dhabi (Native-India)
    506
    Default Re: Purge Blocks Only
    Quote Originally Posted by wpeacock
    Wayne
    That's one of the easiest things we can do
    on error resume next
    dim objBlock as AcadBlock
    for each objBlock in thisdrawing.Blocks
       objBlock.delete
    next
    Do not remove 'On Error' statement as an error will be generated while trying to delete a referenced block.
    har!s
    CADing && Coding
    AuotCAD 2010 on Windows XP Professional (SP3)
    Active Member rcrabb's Avatar
    2007-02
    99
    okay, so after i do that, why is this not inserting the new block i select?
    UserForm1.dlgOpenFile.Filter = "AutoCAD Blocks (*.DWG) | *.dwg"
    UserForm1.dlgOpenFile.InitDir = Application.Path
    UserForm1.dlgOpenFile.ShowOpen
    pt1(0) = 0: pt1(1) = 0: pt1(2) = 0
    scXYZ = 1
    RotAng = 0
       Dim objNewBlock As AcadBlock
       Set objNewBlock = ThisDrawing.ModelSpace.InsertBlock(pt1, _
                         UserForm1.dlgOpenFile.FileName, scXYZ, scXYZ, scXYZ, RotAng)
    Forum Manager, Administrator Ed Jobe's Avatar
    Turlock, CA
    4,791
    Have you verified that FileName contains a valid file path?
    C:> ED WORKING....
    2007-02
    99
    Quote Originally Posted by Ed Jobe
    using Debug.Print I get K:\AutoCad\TitleBlocks\HOME_1__Alum_Extru_A size_Portrait.dwg
    I would assume that is valid? Or do I need to use a form of "../" to escape from the default directory that AutoCAD uses? What is the default dir?
    Thanks Ed!!
    Turlock, CA
    4,791
    But is it valid at the point that the Insert method calls it? Insert a breakpoint at that line and check it at runtime.
    C:> ED WORKING....
    2007-02
    99
    ... i think im in over my head here ... maybe my ss can answer that question, because i know i cant
    Turlock, CA
    4,791
    I don't know, it looks ok from what I can see on the screenshot. What about normal cad issues? Inserting on a layer that's off, etc.?
    C:> ED WORKING....
    2007-02
    99
    i dont know, grr, im so frustrated ...
    Ed - If you get any free time, would it be possible for me to send you the drawing im attempting this routine on, and you could maybe identify the problem that I fail to?
    Turlock, CA
    4,791
    Attach the file and dvb to this thread and somebody should be able to look at it.
    C:> ED WORKING....
  1. Can not purge blocks from table
    By costas.vassiliou in forum AutoCAD Tables
    Last Post: 2011-06-13, 10:48 PM
  2. Purge textstyles in blocks
    By david.hellberg in forum ACA General
    Last Post: 2009-01-09, 10:49 PM
  3. How to purge phantom blocks?
    By jf1725 in forum AutoCAD General
    Last Post: 2006-07-27, 01:52 PM
  4. How to purge these naughty blocks?
    By pravin_kulkarni in forum MDT - General
    Last Post: 2005-09-26, 08:03 AM
  5. purge all not purging *__ (blocks)
    By michael.byrne in forum CAD Management - General
    Last Post: 2004-06-10, 06:06 PM
