Thread: ...drawing contains authoring elements. Open in block editor?
    2002-01
    98
    Default ...drawing contains authoring elements. Open in block editor?
    I just opened a drawing and got the message "...drawing contains authoring elements. Open in block editor?"
    It seems like this is a dynamic block that exists in a drawing without actually being a block - if that makes sense. In other words if I open the drawing directly (if i ignore the message) there are no blocks in the drawing. But it can be inserted into another dwg and behave like a dynamic block.
    I have created dyn. blocks. But only know how to create them as a 'fully formed' block within the drawing & must insert & explode to get to the actual dyn. block.
    How does one do the dyn. block without actually having to have a nested block?
    If my questions are not clear, please let me know and i will try to clarify.
    2005-07
    2,355
    Default Re: ...drawing contains authoring elements. Open in block editor?
    This and this may explain.
    Dynamic Blockhead Mod Chris.N's Avatar
    2001-12
    Rochester, MN
    2,561
    Quote Originally Posted by pmedina
    <snip>
    i did a quick search for "WBLOCK" and found THIS thread at the top of the list... hopefully it makes sense once you get to the end.... (sorry for my previously worthless link)
    S&D DB Sharing Forum
    2008-03
    331
    Talking Re: ...drawing contains authoring elements. Open in block editor?
    No neew for wblock. Just insert it and it will be fine.
  1. Dynamic Blocks.dwg contains authoring elements. Open in Block Editor?
    By johnd in forum Dynamic Blocks - Technical
    Last Post: 2011-07-07, 12:40 PM
  2. Make an open drawing visible in the drawing editor
    By victorbarrage528662 in forum AutoLISP
    Last Post: 2011-02-10, 12:15 AM
  3. Replies: 2
    Last Post: 2011-02-10, 12:11 AM
  4. Dynamic Blocks.dwg contains authoring elements. Open in Block Editor
    Last Post: 2007-04-18, 08:36 PM
  5. When I download and open DB I see the following message - contains authoring elements
    By neilchristopherwhite in forum Dynamic Blocks - Technical
    Last Post: 2006-01-06, 01:22 PM
