Thread: Show 3D UCS Icon
    2006-10
    Default Show 3D UCS Icon
    Hi,
    It was requested by a client that our AutoCAD 2005 drawings are saved as "3D" files.
    The drawings we created are standard 2D sheets using Paperspace environment.
    Does anyone know if there is a setting within AutoCAD that can make our sheets compliant?
    Client stated something about the tray UCS Icon would show a "Z" symbol within the UCSIcon, currently it just shows X and Y, with the "Z" going into screen depth....
    Thanks!
    AUGI Addict Maverick91's Avatar
    Grand Prairie, Texas, USA
    1,312
    Default Re: Show 3D UCS Icon
    Quote Originally Posted by nathan.wageley
    Hi,
    Thanks!
    What kind of drawing work are you doing? Machine parts? Architectural? Engineering?
    Is your drawing a purely 2d drawing, or are there any z-coords in play?
    Drawing files are almost always three-dimensional by their very nature. This statement from your client may just be some fancy phraseology.
    Just for edification, check the UCSICON command in the ACAD help index.
    Autodesk Civil3D 2018, Revit 2018
    Gig 'Em, Aggies!
    100 Club bmonk's Avatar
    2005-11
    ...1st & 1st...Im at the nexis of the universe...
    159
    Hi,
    Thanks!
    To get your UCS to show a "Z", then you need to use the SHADEMODE command to switch to the 3D setting. This however may display your drawings in ways that you did not intend. Such as hidden lines showing up continuous.
    But, like Doug stated above me, you can use the UCSICON command, and type "P" for properties, and change the look of the icon there.
    HTH
    2005-06
    in the upper right corner
    3,049
    Thumbs up Re: Show 3D UCS Icon
    Maybe they're just referring to a 3-D view, which shows the usc with all 3 directions?
    Go to the "View" pull down, go to "3D views" and select one of the bottom "Isometric" views.
    This gives you an isometric view of your work regardless if you have 3d stuff.
    Ted
    ____________________________________________________________________ ________________
    Windows 7 Professional
    AutoCAD 2017 - REVIT 2017 - Inventor Professional 2015 (when I can)
  1. UCS Icon to show Name of Current Coordinate System
    By acadwishlist in forum AutoCAD Wish List
    Last Post: 2013-10-13, 05:26 AM
  2. Show On-screen Icon for Off-screen Osnaps
    Last Post: 2009-01-26, 05:05 PM
  3. Show actual linetype & color in Tool Palette icon
    By dc.109967 in forum AutoCAD Customization
    Last Post: 2006-11-23, 05:14 PM
  4. Replies: 2
    Last Post: 2006-05-18, 01:39 PM
  5. Tool Palette Icon not matching Toolbar Icon
    By bowlingbrad in forum AutoCAD Customization
    Last Post: 2005-11-02, 08:10 PM
