Results 1 to 9 of 9
Thread: Create / Setup shortcut for ALIGN command?
    Active Member Cadtharsis's Avatar
    2006-02
    Pi World. It's not what I was thinking. :(
    90
    Unhappy Create / Setup shortcut for ALIGN command?
    I can't seem to find any other way of entering the align command than typing the word "ALIGN". Is there a shortcut (I don't want a toolbar button!), and if not, how could I set it up to be, say, "AG" or something? (AL and ALI, are taken already)
    All AUGI, all the time Mlabell's Avatar
    2004-12
    Toledo, OH
    513
    Default Re: Create / Setup shortcut for ALIGN command?
    Quote Originally Posted by tburns
    AL is the factory setting of align, so it must have been reprogrammed, to change it goto Tools>Customize>Edit program parameters. Just a note use this version and not the express tools version of pgp editor, and also place all cutomizations at the end of the file.
    Text entered should be this (AG, *ALIGN)
    2006-02
    90
    That didn't work at all. And when I use AL, it starts some AutoLog command, which gets me to a dialogue box I don't understand. I checked in that file and AL is indeed set to ALIGN. I tried adding the text you gave me at the end it it had no effect.
    150700
    3,439
    A few things - you could have edited the wrong PGP file or you could have a third party program that is overriding that command (probably, since it was overwritten in the first place).
    150700
    3,439
    Also - vanilla AutoCAD or a vertical application?
    2006-02
    90
    AutoCAD 2005, and we have Toolpac.
    150700
    3,439
    I'll bet it's a toolpac quickkey. Check out your Toolpac quickkeys and see if it's defined in there; they will override the AutoCAD PGP file shortcut keys
    2006-02
    90
    Ah, it was. However, I proceeded to delete it from the quick keys, and after doing so, AL still does "Autolog"
    2006-02
    90
    It appears today is the day for things suddenly working. On a whim, I updated toolpac. The AL quickkey was still deleted, and I typed in AL. I got ALIGN this time.
    I'm not going to argue, it worked. *Shrug*
  1. create typed shortcut for command group
    By archiasmo954906 in forum API Wish List
    Last Post: 2012-10-29, 10:01 PM
  2. Create Windows XP Shortcut
    By BlackBox in forum AutoLISP
    Last Post: 2010-08-02, 09:39 AM
  3. ALIGN COMMAND
    By jayzar in forum AutoCAD General
    Last Post: 2008-12-03, 01:26 PM
  4. MDT 2006 - Create shortcut key's
    By Viatcheslav.Samsonov in forum AutoCAD CUI Menus
    Last Post: 2006-07-01, 08:12 AM
  5. Create own Shortcut Keys
    By basha_sk312 in forum AutoCAD CUI Menus
    Last Post: 2006-03-15, 08:37 PM
