I am trying to split a wall corner with a 45 degree miter cut but am finding the split command seems to work at 90 degress. Any suggestions? Thanks
The split command will only 'break' a wall at a 90. It is generally used to create two separate wall segments from one wall.
If you need to you can create an in-place void family to carve the corner the way you want. Be sure you create it as a 'wall' category and use the cut geometry tool beofre you exit the family edit mode.
Rick, Are you leaving the corner exposed? Is that why you need a 45 miter? Or are you looking for the Edit wall join tool? This tool asks you to pick a corner, then at the top of the screen you can pick either butt join or miter...
