Results 1 to 10 of 13
Thread: Aligning circles
    Member brakware's Avatar
    2006-11
    Seattle, WA
    32
    Default Aligning circles
    I am trying to array a tubular extrusion. The problem is that if I try to align the tube while in sketch mode (creating the extrusion), then, when I try to array the tube, it says that the group is constrained to something outside of the group and either I need to remove the constraints or cancel the operation. This means that I have to constrain the first item in the array and the second/last (respectively) item after I array the object. Tricky thing is, though, that I cannot align my tubular extrusion to anything because I cannot align the center to anything after I am out of sketch mode.
    My thought on a solution was to make the object a separate family and nest it in the current one, then I could have symbolic lines or reference planes to align to, but for the family that I am building, I need to complete all the pieces of it, and then do a void cut over all of the objects so that it is in a wedge shape. Void cuts will not cut nested families (or at least, when I tried briefly to do it, it wouldn't work).
    Does anyone know of a solution for this, or has anyone run into this problem before? I have spent a lot of time on this family, and it will save us tons of time in the future if I can get it right. If anyone has any suggestions, I welcome them. Thanks in advance.
    2002-02
    St. Louis, MO
    4,695
    Default Re: Aligning circles
    Select said circle. Go to the properties and turn on the "Center Mark Visible" Use align. Have a nice day....
    2006-11
    Seattle, WA
    32
    Tried that. Once it is extruded and I am out of sketch mode I cannot align the center of the circle to anything.
    Early Adopter sbrown's Avatar
    2003-05
    Coast to Coast
    4,440
    put some ref planes in or make a symbol line with the center marks turned on.
    Scott D. Brown, AIA
    BECK
    100 Club jamie.casile80054's Avatar
    2004-12
    rock in the middle of the Pacific
    191
    aloha,
    could you post an image? i'm having a hard time visualizing what you're trying to accomplish.
    -jamie
    Jamie Casile
    CAD/BIM Manager
    Pacific CADD Services, Inc.
    ...My Lomography Page...
    AUGI Addict luigi's Avatar
    2015-11
    Royal oak, Michigan
    1,513
    Since it sounds like it is from within an inplace family, have you tried adding 2 ref. place that intersect the circle (Center L/R and Center F/B) defining origin....then the center will be selectable and alignable
    Quote Originally Posted by brakware
    2002-02
    St. Louis, MO
    4,695
    You align the circle while in sketch mode to a ref. plane or other object.
    2006-11
    Seattle, WA
    32
    This is not an in-place family, this is a stand-alone "generic model" family.
    I cannot constrain the circle while I am in sketch mode, because, as I said in my original post, if I constrain it while in sketch mode I cannot array the extrusion outside of sketch mode. I also cannot array the circle while in sketch mode.
    I cannot constrain the resultant extrusion to anything (reference planes, reference lines, symbolic lines) that I can later constrain to something because Revit is not giving me anything in the extrusion to constrain to other objects with. Also, if I could constrain it to something like a reference plane/line/etc., I would not have a problem. Revit will not let me constrain the extrusion to anything that helps me, even to a circle of the exact same size.
    Because I need to array the extrusion (so that the number of the array can adjust to spacing and length), I cannot try to constrain any part of my extrusion until after I have arrayed it. At such point I can only constrain the first object in the array, and the second/last (respectively) object in the array.
    I will try to put together an image of what I am trying to do to post it.
    2002-02
    St. Louis, MO
    4,695
    Like this.... You use old school Revit circles in this case. This technique has a lot of other applications.
    2006-11
    Seattle, WA
    32
    I am running 8.1. The family you sent says that it was saved in a later version and cannot be retrieved.
  1. Points to Circles
    By vijaybaskergundla in forum AutoLISP
    Last Post: 2017-10-10, 01:05 AM
  2. circles within circles...
    By IamMichaelPacker747327 in forum AutoCAD General
    Last Post: 2012-04-30, 08:03 PM
  3. 2012: Concentric Circles
    By dherbstr in forum Dynamic Blocks - Technical
    Last Post: 2011-12-02, 07:30 PM
  4. Aligning to Centerlines of Circles?
    By jhh in forum Revit Architecture - General
    Last Post: 2007-03-01, 05:21 PM
  5. Filling circles
    By leosgott in forum AutoCAD Map 3D - General
    Last Post: 2005-04-27, 03:27 AM
