I created a level tag block with a field to grab the Y value of the blocks insertion point. This tag is to be used in a drawing containing the elevation tags only. This drawing is then referenced into all our elevations and sections to insure consistency between drawings. The tag works well within the drawing to be xreffed, but when referenced all fields display a value of 0'-0".
We use different UCS in our elevations-sections, so I checked xreffing the level tags in WCS, but got the same problem, so I wanted to ask if someone has managed to accomplish what we are trying to do. I am attaching the block in case someone would like to take a look.
