Results 1 to 7 of 7
Thread: How do you un-union (separate) two solids?
    2003-09
    Santa Barbara, Ca - San Jose, Costa Rica
    182
    Default How do you un-union (separate) two solids?
    How do you UN-union (separate) two solids?
    Thank you!
    Armando M. Arias del Cid
    All AUGI, all the time zoomharis's Avatar
    2005-02
    Abu Dhabi (Native-India)
    506
    Default Re: How do you un-union (separate) two solids?
    Quote Originally Posted by ariasdelcid
    Thank you!
    As far as I know, you can not separate boolean objects that form a single volume. But for objects with disjointed volumes (Single object with two or more volumes standing independently ) you can use 'Seperate' option in the SolidEdit command to separate them.
    har!s
    CADing && Coding
    AuotCAD 2010 on Windows XP Professional (SP3)
    0,0,0 The Origin
    8,569
    Other than that ^^, the best you can do is Slice the parts.
    John B
    Active Member fhoffnar's Avatar
    2007-01
    Hudson Valley, NY
    99
    If you have solid history on you may be able to CTRL+ click the object and simply drag it out of the other object.
    EDIT: With SOLIDHIST off you can grab features and 'pull' them out of the solid. You need to run the separate command.
    2005-02
    506
    Quote Originally Posted by fhoffnar
    Great tip... You can use this option for converting boolean objects with a single volume into disjointed volumes. Please note that you still have to use Seperate option in the SolidEdit command to make them different solids. Thanks for the tip.
    har!s
    CADing && Coding
    I could stop if I wanted to ronie_ernanto's Avatar
    2006-11
    Jauh di Sidoarjo sana (Indonesia)
    312
    Disadvantage of using solid history is your file size will growing bigger..
    2007-04
    8
    Great tip fhoffnar. I think that's the best you're gonna do without 3rd party add-ons(I know AutoSolids can undo booleans).
  1. Replies: 2
    Last Post: 2015-09-11, 08:57 PM
  2. 2014: Microstation Solids to Autocad Solids
    By boyerd492098 in forum AutoCAD General
    Last Post: 2014-05-28, 05:14 PM
  3. 2012 Separate two solids from same image
    By Darren Allen in forum AutoCAD Mechanical - General
    Last Post: 2013-06-11, 07:00 PM
  4. Separate 3D Composite Solids
    By acadwishlist in forum AutoCAD Wish List
    Last Post: 2008-06-14, 01:19 PM
  5. Are you Union?
    By Wanderer in forum CAD Management - General
    Last Post: 2006-02-24, 07:55 PM
