Thread: An Ivy Generator Program - Free!
    Design Visualization Moderator stusic's Avatar
    2004-10
    N32° 32' 19.08", W-84° 52' 59.03"
    1,272
    Thumbs up An Ivy Generator Program - Free!
    Okay, now I've got to try this: an open-source program that generates ivy in your scene. Fully licensed for commercial use, you can use it in your projects with no problem.
    Has anyone used this before? After looking at dellis' thread on crawling vines, I started looking into how to efficiently do something similar and ran across this. Interested to know how it goes.
    Phillip Bradshaw
    Lead Pixel Pusher, Lucid Design Studio
    CAD Administrator, Heatcraft RPD
    A doctor can bury his mistakes but an architect can only advise his clients to plant vines. - Frank Lloyd Wright
    I could stop if I wanted to loydg's Avatar
    2007-08
    Denver, CO
    323
    Default Re: An Ivy Generator Program - Free!
    I've used this program for a few projects. It's pretty cool, even if a bit awkward to use at first. The ivy objects it produces are sweet. Only downfall is poly count. Plan on some long render times if using raytrace or any GI. I ended up rendering out large portions of just the ivy in a front viewport with alphas and then using those as diffuse and oppacity maps.
    Glen Loyd
    Parsons Brinckerhoff
    Lead Design Visualization Specialist
    3ds Max Design 2010 Certified Associate/Professional
    www.pbprojectviz.com
    www.pbviz.com/forum
    2007-08
    Denver, CO
    323
    An image would be helpful too...
    The retaining wall on the right has the ivy from the generator on it. The foreground ivy is 3D and as it gets farther back becomes a map on a simple object.
    Glen Loyd
    www.pbviz.com/forum
    I could stop if I wanted to dellis's Avatar
    2003-12
    Windsor, Ontario, Canada
    379
    This program is really cool....but the amount of geometry created is pretty much why i went the particle flow route. Great images by the way!
    What tree program are you using for the ones in the last image?
    2007-08
    Denver, CO
    323
    Quote Originally Posted by dellis View Post
    I this scene we used a combination of X Frog up close and then Forest Pro in the distance. Although this project was before we discovered the power of V-Ray Meshes. Now we can have thousands (I've pushed 45,000 in one scene) of 3D trees at 150,000 to 300,000 polys each. Interestingly enough, render times are not as bad as you would think. Up to 10 minutes per frame with motion blur turned on (5 without).
    We also use Onyx Tree/Treestorm. It has a great ability to randomize on creation. Very slick.
    Glen Loyd
    www.pbviz.com/forum
  1. Keynote Database Generator - free
    By stellarblue153 in forum Revit - R & D Lounge
    Last Post: 2010-04-09, 07:16 PM
  2. Free compiler to program in C++?
    By clovis in forum ARX
    Last Post: 2006-08-15, 05:12 AM
  3. Free 3D Rendering Program
    By Crosseyed in forum Revit - Rendering
    Last Post: 2006-04-15, 08:16 PM
  4. Free 3D Rendering Program
    By Crosseyed in forum Revit - Gallery
    Last Post: 2006-04-15, 01:38 AM
  5. Free image program
    By Glenn Pope in forum Software
    Last Post: 2005-11-21, 06:32 PM
