Thread: VIZ 2006 crashes when importing DWG file from AutoCAD 2006
    Member fat.mongrel's Avatar
    2007-03
    6
    Default VIZ 2006 crashes when importing DWG file from AutoCAD 2006
    I'm medium VIZ user and I recently imported the license from my old computer.
    The program works ok, so far, on all its features but every time I try to import a dwg from AutoCAD 2006 into AutoVIZ 2006 it crashes and turns VIZ off!!!
    Can anyone help???
    Cheers
    Ivan
    Administrator Steve_Bennett's Avatar
    2004-05
    Somewhere near there
    4,627
    Default Re: VIZ 2006 crashes when importing DWG file from AutoCAD 2006
    What stage does it crash out VIZ? Do you at least get a progress bar? If it crashes immediately after clicking the ok button on the import box, then it might be VIZ related - try a repair of your VIZ install. If it crashes during import after a progress bar is going, it might be the autocad dwg. Make sure the contents in the dwg are close to 0,0,0 and that there are no errors in the dwg. If these suggestions dont work for you, please post the dwg here so i can try to reproduce the issues.
    Steve Bennett / CAD Manager
    HMC Architects / Adventures in BIM
    2007-03
    6
    it crashes midway the import process, I do get the progress bar, sometimes just the beginning and sometimes close to the end... and good bye!!!
    Seems to be a problem with VIZ, because it happens with any file!!!
    Sorry but I cant post the file...
    Cheers
    Ivan
    2004-05
    4,627
    Well, you can try repairing VIZ then - that's always worth a shot. Also, are you running the SP for VIZ?
  1. Replies: 19
    Last Post: 2007-03-12, 05:46 AM
  2. AutoCAD LT 2006 - importing JPEG's
    By Slash in forum AutoCAD LT - General
    Last Post: 2006-08-09, 12:33 PM
  3. Replies: 2
    Last Post: 2006-05-30, 08:03 PM
  4. AutoCAD 2006 crashes about every 45 minutes while Panning?
    By 09silverado in forum AutoCAD General
    Last Post: 2006-05-25, 11:43 AM
  5. Importing excel into AutoCAD 2006 & 2005
    By MikeM4OSU in forum AutoCAD Tables
    Last Post: 2005-06-14, 02:50 PM
