Thread: Multiple Soldier Courses in Masonry Wall
    Woo! Hoo! my 1st post kst8arkitekt's Avatar
    2007-03
    Default Multiple Soldier Courses in Masonry Wall
    I am trying to create a masonry wall that has two brick soldier courses. One is at 2’-8” to 3’-4” and the other is at 8’-0” to 8’-8”. The soldier courses are supposed to be recessed from the rest of the brick 3/8”.
    First, can I not just split those regions, somehow delete the brick in those regions, and then do a sweep with the ‘wall sweep – brick soldier course: 1 brick’ profile? The offset for those sweeps is set to -4”, but they do not show up in any views. When I couldn’t get that to work, I then tried to also to do a reveal profile (reveal - brick course: 3 bricks) at those same elevations to form the “cut” so the soldier course shows up. When I do that, the lower one works, but when I do the upper one, I get the following error message: "Could not create integral reveal for wall instance. Failed to cut wall"
    Any suggestions?!?!?
    I could stop if I wanted to Teresa.Martin's Avatar
    2004-11
    438
    Wink Re: Multiple Soldier Courses in Masonry Wall
    Dear Revit User;
    I am not sure why you are getting the error message. Could the reveal/sweep be above the height of the wall? I replicated your situation and both courses showed up so I am not exactly sure why you are getting the error. Please post a rvt file with the aforementioned wall.
    Best regards,
    Teresa Martin
    Senior Application Specialist, IdeateInc
    Ideate on Youtube! http://www.youtube.com/user/IdeateInc
    Ideate Solutions blogs! http://ideatesolutions.blogspot.com/
    Check out my blog: http://bimnewworld.blogspot.com
    2004-03
    Edmonton AB
    10
    Default Re: Multiple Soldier Courses in Masonry Wall
    I would do a stacked wall - you can achieve the pattern you want and also offset the soldier coarses (created as a seperate wall) to the 3/8" you need to achieve.
    2003-09
    1,907
    another option is to reverse your sweeps - have the recess the main wall and add the "normal" brick (running bond) on as a sweep.
    Oh, and welcome to the Forum..
    I could stop if I wanted to Melarch's Avatar
    204
    What happened to vertically compund walls? I did not have a problem creating multiple hosted wall sweeps or reveals using the Host tool on the Modeling tab.
    Mel Persin, AIA
    AEC Technology Consultant
    MasterGraphics, Inc.
    Mel Persin, aia - adjunct instructor, Revit/CAD
    Oakton Community College, Skokie, IL
    Architecture Design/Network Administration/BIM-CAD Consultant
    email:melarch@comcast.net or mpersin@oakton.edu
  1. soldier course at wall openings
    By AG_jten in forum Revit Architecture - General
    Last Post: 2012-09-17, 08:40 PM
  2. Masonry Wall Loads
    By ashwin.rego in forum Robot Structural Analysis
    Last Post: 2010-09-08, 02:01 PM
  3. Curtain wall to angle as it meets masonry wall
    By noelgerardmurphy in forum Revit - Student Support
    Last Post: 2009-12-16, 12:07 AM
  4. Masonry Wall Encap
    By jsnyder.68308 in forum ACA General
    Last Post: 2008-09-02, 10:50 PM
  5. Soldier - Rowlock courses + expansion joint
    By raddis in forum Revit Architecture - General
    Last Post: 2006-10-13, 01:30 PM
