Thread: Multiple Soldier Courses in Masonry Wall
    Woo! Hoo! my 1st post kst8arkitekt's Avatar
    2007-03
    Default Multiple Soldier Courses in Masonry Wall
    I am trying to create a masonry wall that has two brick soldier courses. One is at 2’-8” to 3’-4” and the other is at 8’-0” to 8’-8”. The soldier courses are supposed to be recessed from the rest of the brick 3/8”.
    First, can I not just split those regions, somehow delete the brick in those regions, and then do a sweep with the ‘wall sweep – brick soldier course: 1 brick’ profile? The offset for those sweeps is set to -4”, but they do not show up in any views. When I couldn’t get that to work, I then tried to also to do a reveal profile (reveal - brick course: 3 bricks) at those same elevations to form the “cut” so the soldier course shows up. When I do that, the lower one works, but when I do the upper one, I get the following error message: "Could not create integral reveal for wall instance. Failed to cut wall"
    Any suggestions?!?!?
    I could stop if I wanted to Teresa.Martin's Avatar
    2004-11
    438
    Wink Re: Multiple Soldier Courses in Masonry Wall
    Dear Revit User;
    I am not sure why you are getting the error message. Could the reveal/sweep be above the height of the wall? I replicated your situation and both courses showed up so I am not exactly sure why you are getting the error. Please post a rvt file with the aforementioned wall.
    Best regards,
    2004-03
    Edmonton AB
    10
    Default Re: Multiple Soldier Courses in Masonry Wall
    I would do a stacked wall - you can achieve the pattern you want and also offset the soldier coarses (created as a seperate wall) to the 3/8" you need to achieve.
    2003-09
    1,907
    another option is to reverse your sweeps - have the recess the main wall and add the "normal" brick (running bond) on as a sweep.
    Oh, and welcome to the Forum..
    I could stop if I wanted to Melarch's Avatar
    204
    What happened to vertically compund walls? I did not have a problem creating multiple hosted wall sweeps or reveals using the Host tool on the Modeling tab.
    Mel Persin, AIA
    AEC Technology Consultant
    MasterGraphics, Inc.
  1. soldier course at wall openings
    By AG_jten in forum Revit Architecture - General
    Last Post: 2012-09-17, 08:40 PM
  2. Masonry Wall Loads
    By ashwin.rego in forum Robot Structural Analysis
    Last Post: 2010-09-08, 02:01 PM
  3. Curtain wall to angle as it meets masonry wall
    By noelgerardmurphy in forum Revit - Student Support
    Last Post: 2009-12-16, 12:07 AM
  4. Masonry Wall Encap
    By jsnyder.68308 in forum ACA General
    Last Post: 2008-09-02, 10:50 PM
  5. Soldier - Rowlock courses + expansion joint
    By raddis in forum Revit Architecture - General
    Last Post: 2006-10-13, 01:30 PM
