I am trying to create a masonry wall that has two brick soldier courses. One is at 2’-8” to 3’-4” and the other is at 8’-0” to 8’-8”. The soldier courses are supposed to be recessed from the rest of the brick 3/8”.
First, can I not just split those regions, somehow delete the brick in those regions, and then do a sweep with the ‘wall sweep – brick soldier course: 1 brick’ profile? The offset for those sweeps is set to -4”, but they do not show up in any views. When I couldn’t get that to work, I then tried to also to do a reveal profile (reveal - brick course: 3 bricks) at those same elevations to form the “cut” so the soldier course shows up. When I do that, the lower one works, but when I do the upper one, I get the following error message: "Could not create integral reveal for wall instance. Failed to cut wall"
Any suggestions?!?!?
