Hello,
I have been experimenting with using pipes (No Structures so far) for my entrance culverts under driveways in areas that we have open ditches. We have alot of these type roads in Kansas. I tried this because if I use the pipes I can pull a label for the existing pipe right from the data of the pipe size, along with the Station if I need it.
I would like to be able to use the pipes for my new proposed culverts also but have run into a little bit of a snag. We require that all new culverts be installed with end sections. Would these be a "structure"? Or is this even possible?
I like the idea of using pipes for these because they can be easily added to the profile view and should show up in the cross sections if a cross section happens to fall in the middle of a driveway.
Any help would be greatly appreciated.
Daryl
