Thread: Linking AutoCAD Object data directly to Excel
    2004-12
    80
    Default Linking AutoCAD Object data directly to Excel
    Does anyone know of Cad software that links a rectangle or polygon to a spreadsheet such that when the area of the rectangle changes, the spreadsheet automatically updates with the new area?
    Thanks
    150700
    3,434
    Default Re: Linking AutoCAD Object data directly to Excel
    Quote Originally Posted by Shizzjr
    Thanks
    with AutoCAD 2008, you might be able to use fields and table to do this, but I am not 100% sure...
    2002-09
    Madison, WI
    5,474
    Thanks
    With both ACA/ADT & Revit you can create the schedule in the program that is linked to the space and will update automatically. I believe that you can export the schedule to Excel and I don't know if you can link it in real time.
    Dave Peterson
    BIM Coordinator
    Acad - 2016 - Revit 2018 w/ A360 - Navisworks - 3ds 2018 - Ensacpe - Lumion - Win 7 64 - i7-6700K 4.0GHz 32GB DDR4 Ram - Nvidia Quadro K2200
    "The more you know, the less you know, because the more you know you don't know". --M. Lin
    2006-02
    Croswell, Michigan
    80
    You can copy excel information to your clipboard and then edit/paste special inside CAD, check link, then paste it. Although if you document increases in size, length or width then it will appear wrong inside CAD. At this point you'll have to copy and repaste again. If the document if final before you paste the first time, this will not be an issue.
    Have a Great Day
    William.Biskey
    2006-01
    Land of chocolate
    228
    yes - my first guess would be fields and autocad tables as well - AC2008 has a few small extensions on tables, but think it should work in earlier versions as well - as long as you can insert a field into a table cell.
  1. linking field data to other object data
    By keith_velishek in forum AutoLISP
    Last Post: 2014-03-23, 03:53 AM
  2. 2012: Linking object in a drawing to an external Excel Spreadsheet
    By bethelcad370537 in forum AutoCAD General
    Last Post: 2013-04-16, 01:34 PM
  3. Linking data from excel to acad
    By csimpson468575 in forum AutoCAD General
    Last Post: 2012-02-22, 12:19 AM
  4. Linking AutoCAD Object Data Table to Access table
    By m.storey in forum AutoCAD Map 3D - General
    Last Post: 2006-05-02, 02:54 PM
  5. Linking Excel Sheet as OLE object
    By jmckiness in forum AutoCAD LT - General
    Last Post: 2005-08-25, 11:43 AM
