Results 1 to 9 of 9
Thread: Grids in Title Blocks?
    2001-12
    1,713
    Default Grids in Title Blocks?
    So I am wondering what people are doing to create some sort of reference grid in the sheet family, and make it disappear for plotting. The approach the office has been using is to have different TB types, one with grids, one without. But then you have to go sheet to sheet to change them, which is kind of a pain. In a perfect world there would be a way to add a Project Information item called Ready to Print or something, and tie the visibility of the grid to that. Another option is to just have the one type, and just go change the type as needed, but editing types in the family editor is not something everyone is going to know how to do. So then I thought perhaps I could use the API to make a tool that toggles the grid on and off in the TB family for you. But I don't think the API can access the Family Editor, so I can't modify a family with it. I guess at that point I could make it an instance parameter, and use the API to just change all instances?
    Anyway, hoping to hear what others are doing.
    Gordon
    All AUGI, all the time DanielleAnderson's Avatar
    2004-06
    Mostly in Mom-land
    704
    Default Re: Grids in Title Blocks?
    In our titleblock, we have an visibility subcategory called "guidelines". When you don't want that set of lines to print, you go to visibility graphics and turn it off. It works quite well.
    2001-12
    1,713
    Quote Originally Posted by DanielleAnderson
    Hmmm. I assume you still have to go to every view, or have you found a slick way to change the visibility in all sheets? That has been our biggest issue, sheets getting batch plotted and a bunch of grids showing up, resulting in a bunch of paper waste. But perhaps that is where the API could come in? An instance variable in the Sheet and an app that toggles the visibilty in the appropriate sheets only?
    Gordon
    I could stop if I wanted to kpaxton's Avatar
    2004-12
    Sarasota, FL
    492
    I guess it has everything to do with how you're wanting to use the grids. Do you want something you can physically snap to? or just something for a visual reference?
    Within our titleblock, I create grids that use the Invisible Linetype - they're not going to print. To 'use' these, I select the view we'd like to move, then hover over the titleblock which visibly 'turns on' the lines. Then I just move the view where I want it.
    I guess I could also use Danielle's additional idea of placing these in a subcategory and turning them off - IF they get in the way.
    Although you can snap to the invisible lines, unfortunately you don't have the ability to with the geometry within the view we're moving, so it's still an 'eyeball' thing. Keep in mind you do have the 'Workplane Visibility' toggle (blue grid button - part of the Tools button palette) to assist. Set the size of the grid, turn it on, then grab the grips and adjust and move to where you want it.
    -Kyle
    2003-08
    Vancouver, BC Canada
    3,393
    Quote Originally Posted by gordon.price
    You can select multiple views/sheets in the project browser and then apply visibilty, filter, view templates to a whole bunch at once. This also applies to pasting so if you had a set of general notes or a key plan you wnated to add to a number of sheets you can just do it all from the browser.
    ____________________________
    Dimitri Harvalias LEED AP
    Summit BIM Consulting
    BIMblog.ca
    I was never just a CAD monkey, so I refuse to be a BIMpanzee!
    A BIM without the 'I' is just a BM - those in the medical profession know what that amounts to
    100 Club jcdecastro's Avatar
    2006-03
    113
    We use invisible lines in the titleblock.
    The only draw back is always mousing over them. It takes a few months of use to get use to them being there ALL THE TIME.
    All AUGI, all the time ford347's Avatar
    2005-01
    Oroville, CA
    867
    I was using a sub-category of lines called grid lines as Danielle suggested. I went away from that and just put some 'reference lines' in there. Works pretty good. they don't show up, but you can align, snap etc. to these and never have to look at them in your project.
    Josh
    All AUGI, all the time robert.manna's Avatar
    2005-05
    Boston
    777
    We use the subcat approach with a twist. There is a visibility parameter (type based) in the TB families tied to all the grid lines. By default this is turned off in the TB families. If a user wants they can turn the grid lines on, and viola! You've got grids whose appearance can be controlled via object styles, but you don't have to worry about applying and re-applying view templates to modify your views, just throw a simple switch in the TB family.
    On top of that all that, you could create two types within the TB family, one with the grid off or on. So take your pick with my families you can manage the grid lines any way that you want.
    HTH,
    -R
    2004-06
    Mostly in Mom-land
    704
    Great Tip Robert! I'll have to give that a try.
  1. 2012: TITLE BLOCKS
    By ckarl317879 in forum Revit Architecture - General
    Last Post: 2011-12-21, 03:37 PM
  2. Dynamic Blocks in Title Blocks
    By tim.j.sparks in forum Dynamic Blocks - Technical
    Last Post: 2011-03-01, 05:08 PM
  3. Title Blocks
    By dzatto in forum ACA General
    Last Post: 2007-12-27, 05:37 PM
  4. Title Blocks
    By rhayes.99001 in forum ACA General
    Last Post: 2007-01-18, 11:36 AM
  5. Title Blocks
    By jcoe in forum Revit Architecture - General
    Last Post: 2004-08-17, 07:06 PM
