Summary: Acquire the properties of an object and then create a similar object based on those properties
Description: I wish it would be possible to use the middle mouse button to double click on an object and temporary acquire all of its properties, that is:
- object type (line, pline, circle,...)
- layer
- color
- line type
- line thickens
And then be able to draw to draw an object with the same properties. It is similar to the "match properties" tool, but you would use it before you would start to draw an object and it would also include the object type. So to say if you have an red dotted circle on the layer X, you would simple double click on it and you could draw a new circle with the same properties. It would make most sense to have it on something simple like the middle double mouse click so the command could be activated really quickly. It can be used for 2D and 3D object.
I know and am used to this command from allplan, so if someone knows it i am sure you will know about it.
How Used: From my experience it is a very simple command that can can be a great time saver. I would guess that this would be beneficial to everyone. Even long time users that are used to their work habits would probably catch up using this quickly.
Feature Affinity: Drawing Tools 2D
Submitted By: saso badovinac on February 22, 2007
