Thread: Window w/ Annotation Text
    2006-05
    43
    Default Window w/ Annotation Text
    Hi all -
    I'm using an annotation text family (attached) to notate blackout windows on a school project - an example of the window with the nested family is also attached. I've made it an instance parameter within the window family, so it only shows up if I turn it on - but it shows through on multiple floor plans, not just on the level I want it to.
    Also, I'm using the same annotation text family to label custom curtainwalls that are modelled as in-place families - and the text shows up when I put it in, but then disappears from view in the original once I've opened another floor plan - the funny thing is that the text will show up in the new floor plan, but not appear in the original unless I edit the in-place family.
    Thoughts?
    Thanks, as always.
    Cheers,
    Pete Wilson
    I could stop if I wanted to dduarte's Avatar
    2005-03
    Santa Barbara, CA
    488
    Default Re: Window w/ Annotation Text
    I usually just use the window tag.
    If the Bottom Plane in the View Range intersects your window, nested annotations will show.
    David Duarte
    Appleton & Associates, Inc.
    Revit Beginners
    I have heard enough to know that you can never hear enough to know.
  1. Window Family Annotation w/ Nested Door System
    By Terry Richardson in forum Revit Architecture - Families
    Last Post: 2010-07-31, 03:49 PM
  2. Differing Heights of Text in one text window
    By titanfirm in forum Revit Structure - General
    Last Post: 2009-05-19, 10:29 PM
  3. Replies: 11
    Last Post: 2006-03-31, 10:04 PM
  4. Annotation (Text) with a box?
    By bgoldman in forum Revit Architecture - General
    Last Post: 2005-12-09, 06:12 PM
  5. window and door size annotation
    By barathd in forum Revit Architecture - General
    Last Post: 2004-08-15, 12:02 AM
