Results 1 to 7 of 7
Thread: LDT 2006 - Plot multiple layout tabs with PUBLISH
    johnvicki
    Guest
    Default LDT 2006 - Plot multiple layout tabs with PUBLISH
    We recently upgraded to LDD 2006
    In LDD 2004 I could choose multiple layout tabs and send them all to the plotter at once.
    In LDD 2006 I can still do the same thing only the methodology is a little different with Publish.
    Our standard setup is to make each tab draft quality. We use this for every day plotting, check plots, etc. My plotter setting in Windows is also draft quality.
    The draft quality is fine unless I have a raster image in my drawing or I need a mylar sheet. In those cases I need to use Normal or Best.
    Here's my problem; Using LDD 2004, if I wanted to plot a higher quality I would select all my tabs, start the plot, click the properties button and change to the desired quality. (Creating a temporary pc3 file.) I do not seem to have that ability in LDD 2007. So far, if I want to print a set of drawings at higher quality I must do each tab individually. Does anyone know how to return my previous ease of plotting to a higher quality?
    John
    john@hymanrobey.com
    I could stop if I wanted to dfarris75's Avatar
    2004-12
    where ever i'm at
    252
    Default Re: LDT 2006 - Plot multiple layout tabs with PUBLISH
    Try utilizing the Sheet Set Manager. This would allow you to select a Page Setup Override file where you could have page setups for final prints vs. draft prints, etc.
    AUGI Addict sinc's Avatar
    2004-02
    Colorado
    1,986
    Or just go into your page setup manager, create a PC3 file that uses the better setting, and create a new page setup that uses the new PC3 file. Then select your new page setup when you PUBLISH.
    But yeah, the SSM can make this whole process faster and easier, and allow you to easily print multi-page plan sets that span multiple DWG files.
    johnvicki
    Guest
    Angry Re: LDT 2006 - Plot multiple layout tabs with PUBLISH
    Thanks, looks like it's SSM for me.
    Why is it that with every release we get some nice improvements while other functions that were behaving quite nicely get un-improved? I now have an added level of complexity for a formerly simple task. Somebody hand me a cryin' towel.
    2004-12
    where ever i'm at
    252
    Actually the SSM is very simple to use, and can improve life for a cadd person when used correctly.
    johnvicki
    Guest
    Thumbs down Re: LDT 2006 - Plot multiple layout tabs with PUBLISH
    Quote Originally Posted by dfarris75
    Maybe so, but it seems that Land Desktop lusers are not good enough for the Sheet Set Manager to be enabled for us.
    AUGI Addict jpaulsen's Avatar
    2002-04
    Colorado
    1,901
    The SSM is fully functional in LDT 2007. I just don't recommend opening drawings with it.
    Jeff Paulsen
  1. Publish selected layout tabs from a single DWG file
    By dzatto in forum AutoCAD Tips & Tricks
    Last Post: 2007-01-03, 01:38 PM
  2. Plot Multiple Layout Tabs
    By Rayllen in forum Land Desktop - General
    Last Post: 2005-11-11, 02:07 PM
  3. Publish layout tabs and layout tab names to PDF
    By dfuehrer in forum AutoCAD Plotting
    Last Post: 2005-11-09, 01:49 PM
  4. Plot Multiple Layout tabs
    By roy.70844 in forum AutoCAD General
    Last Post: 2004-10-07, 03:04 PM
