Results 1 to 10 of 12
Thread: Find existing drawing file scale in Modelspace
    100 Club Binu Mathew's Avatar
    2005-11
    Kuwait
    182
    Default Find existing drawing file scale in Modelspace
    Hi to all,
    Does any one knows how to find the drawing scale of an existing drawing file
    best regrds
    BM
    All AUGI, all the time zoomharis's Avatar
    2005-02
    Abu Dhabi (Native-India)
    506
    Default Re: Find existing drawing file scale in Modelspace
    Quote Originally Posted by BinuM
    Hi to all,
    best regrds
    BM
    Devide total length of the title block by standard sheet size. For example if you have used A1 sheet and the length of title block measures 84100, then the scale will be
    84100 / 841 = 100 (Where 841 is the length of A1 sheet)
    Sometimes you can decide the scale directly by listing the title block.
    har!s
    CADing && Coding
    AuotCAD 2010 on Windows XP Professional (SP3)
    2005-11
    Kuwait
    182
    Quote Originally Posted by zoomharis
    Dear Haris,
    Pls note that i dont have any title or anything how can i find the drawing scale at Model space pls. understand my question...
    Binu
    100 Club Commissar Rod's Avatar
    2006-01
    Harrisburg, PA
    137
    If the drawing lists a dimension, you can measure the distance the dimension is drawn at and then divide the 2 numbers and get the scale that way
    0,0,0 The Origin
    8,569
    If it's all in modelspace, it SHOULD have been drawn at its actual, true, real-world size.
    When required, the drawing border should be scaled up or down to fit around the geometry.
    John B
    13,618
    Hi BM
    Please note I have *moved* this thread from the AutoCAD Gallery forum to this one, as I feel this particular forum is a more appropriate place for such a topic.
    Thanks, Mike
    Forum Manager
    Retired Forum Staff Chris.N's Avatar
    2001-12
    Rochester, MN
    2,561
    Dear Haris,
    Binu
    since the geometry should be drawn full size anyway, can you elaborate and explain why you are asking this question?
    (imperially) sometimes "civil" drawings are smaller by a factor of 12, as their "1" unit = 1 foot, where for me, "1" unit = 1 inch....
    S&D DB Sharing Forum
    2006-01
    Harrisburg, PA
    137
    I agree that good drafting practices would dictate that it be drawn to scale in modelspace, however it is unfortunate that not everyone out there drafts to good standards.
    2005-06
    in the upper right corner
    3,020
    Thumbs up Re: Find existing drawing file scale in Modelspace
    As stated by others, your entities in model space SHOULD be drawn 1:1.
    The time "scale" comes in, is what your final output will be.
    Example: (if in model space) title blocks, dimensions, text, symbols and blocks would need to be scaled up according to your desired output plot scale.
    Do you mean you want to know what "units" the drawing is in?
    (command "ddunits")
    Ususally
    Civil is in decimal units: one unit = one foot
    Or metric units: one unit = one meter.
    Architectural is in architectural units, one unit = one inch,
    Or metric units, one unit = one milimeter.
    My two cents.....
    Ted
    ____________________________________________________________________ ________________
    Windows 7 Professional
    AutoCAD 2017 - REVIT 2017 - Inventor Professional 2015 (when I can)
    100 Club charlie.bauer341340's Avatar
    2002-05
    Here, because I'm not all there
    141
    Quote Originally Posted by tedg
    (command "ddunits")
    Ususally
    My two cents.....
    Based on the information above you should be able to select a known standard object such as a door and deduce the scale from there. For example if you have a door that measures about 3 units it is decimal feet, or if that same door measure about 1 unit it is decimal meters, etc.
  1. Cannot find the specified drawing file
    By ctc in forum DWG TrueView - General
    Last Post: 2010-05-12, 12:49 AM
  2. Replies: 2
    Last Post: 2008-11-04, 08:03 AM
  3. Replies: 4
    Last Post: 2007-01-22, 11:04 AM
  4. Replies: 12
    Last Post: 2006-06-27, 07:45 AM
  5. Find which DWT file was used when creating a drawing
    By Animesh Kundu in forum AutoCAD General
    Last Post: 2006-06-08, 05:14 AM
