Is there a way to reload the rebar system families for sketching rebar if they have been purged out, or do I have to recreate them?
One quick way is to transfer them from another project that already has them using the Transfer Project Standards command. Simply open another project in the same session of Revit (assuming your project template has the rebar families loaded you could also just create a new project). With the project that is missing the rebar active go to File -> Transfer Project Standards. In the dialog that opens make sure the Copy from drop down is pointing to the correct project and then select the Check None button to avoid copying over everything. The checkbox you are looking for is Rebar Types. Select OK and you're all set.
