Results 1 to 6 of 6
Thread: Black Spots with Final Gather...
    2006-08
    10
    Default Black Spots with Final Gather...
    Using Mental Ray (VIZ) I did several test renders and they appear to come out fine, however when I did a finished rendering using final gather there is one area were there appears black spots. Has anyone seen this, and how do I resolve this? I'm using GI as well and have adjusted the photon map accurately in the test renders. Does this have some residual affect on the FG process?
    Design Visualization Moderator stusic's Avatar
    2004-10
    N32° 32' 19.08", W-84° 52' 59.03"
    1,280
    Default Re: Black Spots with Final Gather...
    There are a bunch of things that can cause these spots. Most often though *I think* it's from Reflect/Refract maps; if you have those, try changing them to Raytrace maps...
    Are these spots in low-light areas? This can be compared to a digital camera whose sensor can't detect enough light to get a clear snapshot. Are you using Logarithmic Exposure Control? That can create artifacts also.
    Phillip Bradshaw
    Lead Pixel Pusher, Lucid Design Studio
    CAD Administrator, Heatcraft RPD
    A doctor can bury his mistakes but an architect can only advise his clients to plant vines. - Frank Lloyd Wright
    2004-10
    1,280
    It also occured to me that you may need to adjust the number of photons per sample and/or the average GI photons per light. (if the above solution is not actually a solution )
    Phillip Bradshaw
    2006-08
    10
    So I'm not sure which one, or combination of, fixed the problem, but I increased the photons, increased the "samples per pixel" and samples in the FG rollout...and no more spots...
    Thanks!
    Administrator Steve_Bennett's Avatar
    2004-05
    Somewhere near there
    4,627
    Quote Originally Posted by kms.118789
    Thanks!
    Also, increasing their radius can help...
    Steve Bennett / CAD Manager
    HMC Architects / Adventures in BIM
    2004-10
    1,280
    Thanks!
    Glad it worked for you.
    Phillip Bradshaw
  1. Global illumination and final gather
    By chris_swigert in forum AutoCAD 3D (2007 and above)
    Last Post: 2007-03-04, 05:04 PM
  2. Use GI, Final Gather and other settings within a scene
    By Jmickledesign in forum VIZ - General
    Last Post: 2006-07-07, 11:11 AM
