The problem:
I have an AutoLISP routine that I use to compile data created and embedded in drawings that are electrical cable block diagrams. The data that is extracted is information of the pinning of and the type of cable connectors of both ends of the cable. The AutoLISP routine can extract the data from cables on one drawing sheet or many drawing sheets that are xreferenced in a temporary drawing. This AutoLISP routine outputs the data as 8 ½” x 11” cable connection sheets in AutoCAD drawing format.
What I need this AutoLISP routine to do now is output the same data in the same format into one (1) Excel file with all of the cable connection sheets tabbed.
Can anyone help me and or lead me in the right direction?
I can provide copies of the cable block drawing(s), the AutoLISP routine and the 8 ½” x 11” cable connection sheets.
Thank you for your time, it is most appreciated,
Chris
c_l_maiden@yahoo.com
