Results 1 to 8 of 8
Thread: Fields - show SQ. FT as FT2 instead
    2006-12
    52
    Question Fields - show SQ. FT as FT2 instead
    I'm constantly using a block I've made to grab the areas of a room by checking the area of a polyline. When I use this, the value comes out as "0,000.00 SQ. FT." where I'd rather the SQ. FT. be replaced with Ft². Is it possible to have the program substitute this always or remove it completely?
    Administrator Steve_Bennett's Avatar
    2004-05
    Somewhere near there
    4,627
    Default Re: Fields - show SQ. FT as FT2 instead
    Please note I am moving this to the AutoCAD forums for better coverage on this question.
    Steve Bennett / CAD Manager
    HMC Architects / Adventures in BIM
    All AUGI, all the time Mlabell's Avatar
    2004-12
    Toledo, OH
    513
    In the text/attribute place this after the Field " \U+00B2 " This returns the squared symbol which you request.
    100 Club CADNate's Avatar
    2003-12
    Lovejoy, GA.
    116
    Quote Originally Posted by marklabell
    With what kind of font sytle does this work?
    -Nathan
    Follow me at http://twitter.com/CADNate
    2004-12
    Toledo, OH
    513
    It should work with most .shx files and .ttf files. We typically use either arial type fonts or romans, and it works with those.
    2004-12
    Toledo, OH
    513
    Here is straight from the acad help file (2007)
    You can enter the following special characters and symbols by  entering a control code or a Unicode string. Or in the In-Place Text Editor,  click Symbol on the expanded toolbar.
     Note Symbols are not supported in  vertical text.
         Unicode strings and control codes
         %%d
      \U+00B0
      Degree symbol (°)
       %%p
      \U+00B1
      Tolerance symbol (±)
       %%c
      \U+2205
      Diameter symbol ()
     To insert the following text symbols, click Symbol on the expanded  Text Formatting toolbar or enter the appropriate Unicode string:
         Text symbols and Unicode strings
         Almost equal
       \U+2248
       Angle
       \U+2220
       Boundary line
       \U+E100
       Centerline
       \U+2104
       Delta
       \U+0394
       Electrical phase
       \U+0278
       Flow line
       \U+E101
       Identity
       \U+2261
       Initial length
       \U+E200
       Monument line
       \U+E102
       Not equal
       \U+2260
       Ohm
       \U+2126
       Omega
       \U+03A9
       Plate/property line
       \U+214A
       Subscript 2
       \U+2082
       Squared
       \U+00B2
       Cubed
       \U+00B3
     These text symbols are available in the following True Type (TTF)  and SHX fonts:
    • Simplex
    • RomanS
    • Isocp
    • Isocp2
    • Isocp3
    • Isoct
    • Isoct2
    • Isoct3
    • Isocpeur (TTF only)
    • Isocpeur italic (TTF only)
    • Isocteur (TTF only)
    • Isocteur italic (TTF only)
    2006-01
    The “SQ. FT.” is part of the default field expression text.
    Adding Unicode strings or control codes after the field only add text after the field. They don't change the field expression (you get: "125.0000 SQ. FT.2" instead of "125.0000 FT2").
    Is there any way to edit a field expression or change or delete the default text of the field expression?
    2004-12
    Toledo, OH
    513
    Quote Originally Posted by ericker451
    Change your format to none, then if you go into the additional format you can add a suffix and that is where I would put the unicode for FT2.
  1. Using Fields to show duct sizes
    By ReachAndre in forum AMEP General
    Last Post: 2010-07-29, 11:54 AM
  2. Replies: 7
    Last Post: 2010-01-11, 06:24 PM
  3. Special characters like Ă show as “?” in DTEXT fields
    By jkobishop in forum AutoCAD LT - General
    Last Post: 2010-01-07, 10:43 PM
  4. Fields show nothing?
    By cadman_meg in forum AutoCAD General
    Last Post: 2008-01-11, 04:22 PM
  5. Unused fields need to show as blank
    By eleonard in forum AutoCAD Fields
    Last Post: 2007-10-31, 05:26 PM
