Results 1 to 8 of 8
Thread: A fatal error has occurred
    All AUGI, all the time mwiggins121466's Avatar
    2006-09
    576
    Exclamation A fatal error has occurred
    Has anyone else seen this error? (see attachment) Do you have any idea what is causing it? I get it when I try to save to central. I then did a saveas and exit. I opened the recovery file Revit created and then got an Unrecoverable error (see attachment). Any information would be very helpful. I keep losing work and the project is due Monday.
    Member rafterman's Avatar
    2005-12
    49
    Default Re: A fatal error has occurred
    Did you submit to autodesk support? They are probably your only hope.
    Revit MEP Moderator mjdanowski's Avatar
    2007-03
    890
    yeah, I get it like 5 times a day.
    Usually followed by multiple epithets.
    2006-09
    576
    I have to got through our reseller. Have not gotten much help
    2006-09
    576
    Quote Originally Posted by mjdanowski
    Any idea what causes it? Are you losing work because of it? Any one else at your company getting the same error?
    2007-03
    890
    Quote Originally Posted by mwiggins
    Yes, I have lost work of varying degree (thought usually not that much).
    It happens randomly, but is usually due to me having too many windows open, or trying to do too many things at the same time.
    Either way, it will usually corrupt your local file, and you will need to create a new one for it to stop happening. (at least until you aggravate Revit again)
    All AUGI, all the time kyle.bernhardt's Avatar
    2005-10
    Inside the Factory
    705
    Sounds like you may be running out of memory, which is causing the crash, how much RAM do you have installed on your machine? Have you implemented the "3 Gig Switch"?
    Kyle B
    2006-09
    576
    Kyle,
    I have 3g of RAM and yes we have implemented the "3 Gig Switch". If you want I can provide the local file and local recovery file. We really need to find out what is causing this. Saving to central every 5min is not very productive.
  1. 2014: An error has occurred
    By scottyermer in forum Revit - Platform
    Last Post: 2013-07-24, 09:42 AM
  2. 2012: Revit mep: Export to dwg fatal error. Sync fatal error as well
    By Scottybill in forum Revit MEP - General
    Last Post: 2012-11-30, 09:47 PM
  3. Error closes Revit: An error has occurred while drawing the contents of this window.
    By chasen_forever in forum Revit Architecture - General
    Last Post: 2010-05-07, 03:38 PM
  4. Replies: 2
    Last Post: 2007-03-11, 11:06 PM
  5. Replies: 2
    Last Post: 2005-11-04, 01:46 AM
