Thread: Finish floors you can turn off
    All AUGI, all the time archjake's Avatar
    2003-08
    Tucson, AZ
    531
    Default Finish floors you can turn off
    Finish floors have always been a problem for me. I want them turned on in certain views and off in others. Here is how to do it. Its fast and easy.
    From the menu, go Settings/Object Styles.
    Make a new subcategory under floors. Call it 'FinishFloor' or whatever works for you.
    Now in a plan view make an in-place floor family.
    extrude it from the top of level 1 for example up 1/8" of an inch or so.
    Under properties set the subcategory of the family to 'FinishFloor'. Set the material, finish the family and presto! you have it.
    You can now turn it off separately from your other floors using the standard view settings.
    Jake Boen
    2003-05
    5,153
    Default Re: Finish floors you can turn off
    Thats a handy tip Jake.
    Another approach is to paint the floor with the material finish, then turn off the sub-category "surface pattern" under floors in Visibility settings. For a portion of a large floor, like a Bathroom, you would need to split the face of the floor first before painting.
    Bruce Gow.
    Karel*CAD. Application Specialist..
    Architect.
    Revitalize. Blog
    All AUGI, all the time christo4robin's Avatar
    2003-05
    Boulder, Colorado
    681
    Another solution is to work with worksets. Create a "Finishes" workset that you place finish floors in and simply toggle that workset on and off by view.
    I use this technique with stairs sometimes. I.e., have a rough framing residential stair that has no nosings - it cleans up nicely with floors at the top - then add a second stair object that has finish nosings and treads. Place the second one in the "Finishes" worksets.
    Christopher Herr
    Studio H:T
    Republic of Boulder
    Early Adopter sbrown's Avatar
    2003-05
    Coast to Coast
    4,439
    Chris,
    Awesome idea, great use of worksets. Then you can still use pick walls to define the floor.
    Scott D. Brown, AIA
    Project Coordinator | Director of Building Information Modeling
    HHCP.com
  1. How to create this finish schedule w/ finish key?
    Last Post: 2008-06-24, 04:25 PM
  2. Turn of wall visibility on upper floors...
    By RafeRedmond in forum Revit Architecture - General
    Last Post: 2008-06-23, 11:42 PM
  3. finish plans instead of finish schedules?
    By Justin Marchiel in forum Revit Architecture - General
    Last Post: 2007-02-02, 12:52 AM
  4. Roof Finish Schedule/Finish Key
    By ford347 in forum Revit Architecture - General
    Last Post: 2005-11-14, 01:23 PM
  5. What is corner finish type and host finish type
    By sbrown in forum Revit Architecture - General
    Last Post: 2004-03-04, 08:02 PM
